Hi Darko's, To simply generate a 1024 bit RSA key on the command line use: cert-server (config)#crypto key generate rsa general-keys modulus 1024 The name for the keys will be: % The key modulus size is 1024 bits % Generating 1024 bit RSA keys ...[OK] cert-server (config)#^Zā¦
I have Router Cisco 2811 Bundle w/AIM-VPN/SSL-2,Adv. IP Serv,10 SSL LIC, 64F/256D.
I want to generate RSA key to create secure VPN connection to other CISCO router. How to do it? The key need to have 1024 Bits. Or can I add other RSA key if I have generated it in other way?
In the router, in VPN options there is RSA key feature. I have added a key, but after restarting the router, it disappear?
Thanks
Darko's
In order to automate the configuration of a router I insert the following...
I
igneousnetworks
Hi Darko's,
cert-server (config)#crypto key generate rsa general-keys modulus 1024 The name for the keys will be: cert-server.ignet.co.uk % The key modulus size is 1024 bits % Generating 1024 bit RSA keys ...[OK] cert-server (config)#^Z cert-server #copy run start
If you need a hand with the other elements of setting up the VPN, give me a shout.
Joe ========================== Igneous Networks Technical Director
B
Bandar
Hi Below are a helpfull documents. Cisco Configuration Examples and TechNotes:
Group Encrypted Transport VPN :
D
Darko's
quoted text -
Thank you!!!
Can you please tell me one more think. I have generated the RSA key using RSA option in VPN. Next I saved the RSA key on my PC. But after restarting the router, the key is gone. I think due to the fact that I haven't press the SAVE button. ........... How can be the RSA key upload from my PC? The RSA key on my PC is in .txt file format. Can it be done?
D
Darko's
I
igneousnetworks
Hi Darko's,
I don't know of a method of directly pasting RSA keys into a Cisco configuration from a text file. Probably the quickest way to solve the issue is to generate the keys again. In the future, if you want to store the keys on your PC separately then you need to generate them as 'exportable' and use PEM-formatted files. See:
If you absolutely must use the key that you have previously generated, the only way I can think to proceed is to copy the configuration from the router into a text file. Then add in your key at the relevant point and use TFTP to copy the config back to the router. Messy, but it will get your key in the right place.
Hope this helps.
W
wanyalanabi
Hi Joe,
I was reading through your response. Thanks. I am looking at a similar scenario where I have found the procedure to setup my cisco VPN client to comunicate to VPN IOS router.
However i am not able to key in the command " crypto isakmp policy
3"
Here are the displayed config options:
dmz-i(config)#crypto ca Certification authority engine Enter a crypto engine configurable menu key Long term key operations pki Public Key components wui Crypto HTTP configuration interfaces
dmz-i#show flash
-#- --length-- -----date/time------ path
1 27092556 Dec 24 2004 11:48:30 +00:00 c3845-spservicesk9-mz.
123-11.T2.bin
2 1541 Dec 24 2004 11:55:30 +00:00 sdmconfig-38xx.cfg
3 3885056 Dec 24 2004 11:55:52 +00:00 sdm.tar
4 1463 Dec 24 2004 11:56:04 +00:00 home.html
5 270848 Dec 24 2004 11:56:18 +00:00 home.tar
6 93095 Dec 24 2004 11:56:32 +00:00 attack-drop.sdf
7 1187840 Dec 24 2004 11:56:48 +00:00 ips.tar
8 8019 May 03 2005 07:51:54 +00:00 sart dmz-i#show ver Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version
12.3(11)T2, RELEASE SOFTWARE (fc1) .
I am trying to follow procedure here:
Please advise.
Thanks.
MW
Report Content
ASAP.
