ASDM : connection interrupted
Apr 01, 2008 0 Replies
Good morning everybody,
After successfully configuring NAT on a cisco ASA5510, I have a problem with the ASDM access.
I have created an ssl certificate request, and successfully imported the X509 certificate in the Cisco.
I also had set up a subdomain that points to the external IP address of the Cisco, for instance admin.red2.co.uk.
For privacy reasons, I have changed the subdomain name, which is not admin.
Yesterday, I have successfully acceded the asdm, using http server enable, and adding my IP address.
But now, whe I try to access to the cisco asdm using https secure connection, and port 443, I have the error : "admin.red2.co.uk interrupted the connection."
I had try to debug the connection using the command "debug http 255", but the only message I receive from the console is :
----- red2asa1(config)# listen: Received HTTP request. Started http listen on interface ext port 443
----- Nothing more.
Some other informations may be useful : =========================================================== red2asa1(config)# show crypto ca certificates CA Certificate Status: Available Certificate Serial Number: 04e4da Certificate Usage: General Purpose Public Key Type: RSA (1024 bits) Issuer Name: ea= snipped-for-privacy@cacert.org cn=CA Cert Signing Authority ou=
o=Root CA Subject Name: cn=admin.red2.co.uk PrincipalName: admin.red2.co.uk OCSP AIA: URL:
Validity Date: start date: 15:57:55 GMT Mar 29 2008 end date: 15:57:55 GMT Sep 25 2008 Associated Trustpoints: cacert =========================================================== red2asa1(config)# show crypto ca trustpoints
Trustpoint cacert: Subject Name: cn=admin.red2.co.uk Serial Number: 04e4da Certificate configured. =========================================================== red2asa1(config)# show running-config asdm asdm image disk0:/asdm-523.bin asdm history enable ===========================================================
Any idea ?
