How to block issuing a dhcp ip to a perticular host
Apr 15, 2008 3 Replies
Trendkill
Can you setup a static reservation based on mac, and then give it a non-valid IP? I don't know of any way to do it other than. Technically any port in xyz should be able to issue a dhcp request and get an IP, so you can't block by port or access-list, and you can't disable the…
I have a 1841 cisco router as a dhcp server with 2 address pools namely abc & xyz
ip dhcp pool abc network 10.20.4.0 255.255.255.0 default router 10.20.4.1
ip dhcp pool xyz network 192.50.201.0 255.255.255.0 default router 192.50.201.1
Router is connected to a cisco 2960 switch. It has 2 vlans associated with the 2 address pools.
I have a manual binding to server.
ip dhcp pool serv host 10.20.40.5 client-identifier xxx.xxx.xxxx.xx
when i connect the server to a switch port which is associated with the abc pool it gets the correct manally binded ip.
when i connect it to a switch port which is associated with the xyz pool, it get an ip from that pool. But i want the router to assign only the binded ip when connected to a port associated with the abc pool. If the server is connected to the other vlan port, then it shoul not get an ip.
How can i do this. Please help
Can you setup a static reservation based on mac, and then give it a non-valid IP? I don't know of any way to do it other than. Technically any port in xyz should be able to issue a dhcp request and get an IP, so you can't block by port or access-list, and you can't disable the ip-helper or this would break everything. Therefore, your only course of action is on the dhcp service itself, and by MAC- address which is the only thing the originating station uses to identify itself for static entries.
Why not commit the server to a specific port associated with VLAN abc, and specify the MAC address of the server with the port security command?
e.g.: interface FastEthernet0/3 description Server switchport access vlan switchport mode access switchport nonegotiate switchport port-security switchport port-security violation restrict switchport port-security mac-address aaaa.bbbb.cccc
If the MAC of the server is associated with a specific port, which is associated with a specific VLAN (abc), would that not prevent the server from accessing the DHCP server via any other port, including VLAN xyz ports?
Best Regards, News Reader
Agreed on this solution. I didn't think it would be an option else keeping the server on the same port/vlan would work fine without the mac security, but this would solve the problem.
