Hi all,
does the command "clear ip dhcp bindings *" force the clients to renegotiate the IP address? Or will the client do that only at the dateline fixed by the previuos negotiation?
Alex
Depends on the client. On windows: ipconfig /renew On SUN: ifconfig dhcp extend on others: see the manual pages :-) Your command will clear the binding on the dhcp-server only, there's no mechanism to inform the clients about that fact Mathias
Read the full replyHi all,
Alex
Mathias AM schrieb:
Alex,
No and Yes.
Clients cannot be forced to renegotiate their IP address. If you need to have your clients renegotiate their IP address, lower the lease-duration in advance and then change your DHCP setup. Wait for all hosts to have leases with this new lease-duration before you change the DHCP setup. Only do this if you have a small enough network for the router to cope with the additional DHCP traffic when the lease is shortened. Use a lease-duration of 30 minutes to have hosts acknowledge the change within 30 minutes after the DHCP setup change. When the change has been executed, raise the lease-duration again to acceptable levels.
So this requires planning!
Erik
