How do I configure a cisco 2801 + Etherswitch + SDSL + Cable modem ?
Apr 03, 2005 0 Replies
I just recieved a Cisco 2801 which came with (2) 4-port etherswitch HWIC cards, and i'm trying to configure it. Since I'm not a well versed cisco person (know the basics though), i need some help in knowing if what i'm trying to do is possible. So here are the parameters.
A. My DSL provider gives me a network bridge which has 1 ethernet port, and they provide me with 4 static IP addresses 66.88.88.166/24.
B. My Cable provider gives me 4 DHCP addresses, and a cable modem with
1 ethernet port.
C. My local network is spread through a hub, typical 192.168.0.x/24
I'd like my setup to be able to use ALL 8 IP addresses for internet, and route outbound using the cable addresses, as well as recieve inbound traffic for my mail server, dns server etc. So here how i have things connected. [use fixed font to see my diagram below]
[ Cisco 2081 ] [dsl isp ][DSLBrige ][ 4 port etherswitch ] [cable isp][cablemodem][ 4 port etherswitch ] [ ]local network [ built in port 0/1 ][hub]
All cables are good and working, ports are up/up
My question is: is what i'm trying to do even possible? If so how?
I've noticed a few folks talking about using individual vlans per address, however you cannot mask /32 on a vlan address. so since i have 4 consecutive DSL IP's I dont know how I would be able to use vlan.
Also, I tried using just one of the DSL addresses in a vlan setup, and I was unable to ping my ISPs gateway
Any help would be appreciated.
