Are the cards in a 7206 hot swappable? We need to add an ethernet card but don't really want to power it off. Can we add the card while the router is on and running?
-Matthew
Hi Matthew, You may want to investigate the Cisco 7206 Online Insertion and Removal Guide: this helps. Brad Reese Cisco Repair Worldwide 1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 Toll Free: 877-549-2680 International: 828-277-7272 Website:
Read the full replyAre the cards in a 7206 hot swappable? We need to add an ethernet card but don't really want to power it off. Can we add the card while the router is on and running?
-Matthew
Hi Matthew,
Brad Reese BradReese.Com Cisco Repair Worldwide
yepp - this works. We have quite a number of 72xx running and we're hot-plugging and removing cards all the time. Works fine. In **very rare** cases I have observed that the new card is not recognized (but after removing it and plugging it again it worked). What is more annoying is that there are different flavours of the 72xx, VXR and non-VXR chassis, different NPEs and I/O-Controllers and I have had several cases where a card was simply not supported (chassis too new, too old etc...) in such a case you'll get a log message explaining what went on.
Regards, Axel
On the 7206 only the processor card is not hot swappable. The port adapters are. From the Cisco docs.
bob
