help needed with cable's
Jun 09, 2005 2 Replies
help needed with cable's open original image
for lab purpose i want to connect two cisco 1601R routers thru the serial port.
what for cable's are needed ? I have one v.35 DTE cable.
thanx in advanced !!
Greetings Mark van Strien
You'll need the V.35 DCE Cable on the other side. Should be Cable: CAB-V35FC
Check on
Just connect the routers back to back with the two cables and don't forget to enable the clocking on one of the routers serial interface.
Regards Charly
Mark van Strien schrieb:
Mark,
CablestoreUSA has CAB-V35FC in stock for $28.25
Brian Elder would be your contact:
Sincerely,
Brad Reese BradReese.Com Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Website:
