GRE between Cisco 827 and Juniper ERX
Jul 13, 2006 2 Replies
GRE between Cisco 827 and Juniper ERX open original image
I am currently looking for a working config for a GRE tunnel between a Cisco 827 and a Juniper ERX. The Cisco connects to the 827 via PPPoE. The transport into the DSL cloud is through a L2TP tunnel. Here is what I have so far:
Cisco 827:
interface Tunnel0 ip address 2.2.2.2 255.255.255.252 tunnel source Dialer1 tunnel destination 172.31.80.1 ! interface Ethernet0 ip address 192.168.150.1 255.255.255.0 hold-queue 100 out ! interface ATM0 no ip address no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0.1 point-to-point pvc 8/35 encapsulation aal5snap pppoe-client dial-pool-number 1 ! ! interface Dialer1 mtu 1492 ip address negotiated encapsulation ppp dialer pool 1 ppp pap sent-username *********@*******.*** password 0 ********* ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer1
ERX:
interface loopback 5 ip address 172.31.80.1 255.255.255.0 ! interface tunnel gre:lab transport-virtual-router Lab tunnel source 172.31.80.1 tunnel destination 172.31.80.2 ip address 2.2.2.1 255.255.255.252
Any assistance is appreciated
In Cisco GRE tunnel configuration example, the tunnel source was confiugred as the Ethernet interface not the dialer interface. Not sure if this matters
see ttp://
ttp://
That's a nice page, thanks.
Without hours of study, it looks as if that example uses Ethernet 1 as the external interface and the Original Poster has a dialer on the outside so it is OK.
I have a working GRE tunnel setup but I happened to use the IP address for the source. Now that it has been pointed out I may change that.
interface Tunnel1 ip address a.a.a.a 255.255.255.252 ip mtu 1400 ip tcp adjust-mss 1360 load-interval 30 tunnel source x.x.x.x tunnel destination x.x.x.y
There is a Dialer with a negotiated address x.x.x.x
The cisco end of your config looks OK to me assuming that the negotiated address is
172.31.80.2.
If you run a dynamic routing protocol you should have
ip route 172.31.80.1 dialer 1
to make sure that you do not get recursive routing.
