Graphical configuration interface?
Apr 04, 2006 2 Replies
Dana
Try the cisco documentation site. can also try looking at the documentation for the IOS itself. What are you trying to do.
Is there some sort of graphical configuration software I can buy to manage a Cisco 2600 router?
I'm not a router expert, but I need to be able to make some minor configuration changes (primarily, open and close ports in the firewall) without having to consult a network engineer.
I tried using the command-line, but I was totally lost - couldn't even seem to find the right documentation.
Thanks.
You can also try looking at the documentation for the IOS itself. What are you trying to do.
I would have suggested Cisco's SDM. But that doesn't work with a 2600. (
however, if you enable http server on your router, you can use a web browser to get to the router. I'm afraid you might still be a bit lost as this only provides a gui to the command line commands.
Good luck.
