getting stuck with 10GE cards
May 14, 2007 5 Replies
Jump to replies (5)
Hi there,
I've got a 6506 with a sup720 (WS-SUP720-3B) and 2 WS-X6704-10GE cards. The minimum ios-version is 12.2(17a)SX, but this version has been deprecated. So I tried 12.2(18)SXF (according to one of the s/w matrices) and 12.2(17d)SXB11a, but in both cases, the modules are powered off. In case of SXB11a, I even get 'not supported'. With 12.2(17)SXD, I get "Linecard received system exception" for both cards, and the cards are powered off.
Any ideas ?
Thanks
what size power supplies do you have ?
the 10GE modules suck a LOT of power - 263 WATTS per.
try just one card and see if any change
Open a TAC case, could be a hardware issue.
Scott
IOS version: 12.2(18)SXF6
What is the system power consumption before inserting 10GE cards?
#sh power
system power redundancy mode = redundant system power redundancy operationally = non-redundant system power total = 2940.00 Watts (70.00 Amps @ 42V) system power used = 1806.00 Watts (43.00 Amps @ 42V) system power available = 1134.00 Watts (27.00 Amps @ 42V) Power-Capacity PS-Fan Output Oper PS Type Watts A @42V Status Status State
1 none 2 WS-CAC-4000W-US 3795.12 90.36 OK OK on Note: PS2 capacity is limited to 2940.00 Watts (70.00 Amps @ 42V) when PS1 is not present Pwr-Requested Pwr-Allocated Admin Oper Slot Card-Type Watts A @42V Watts A @42V State State
1 WS-X6416-GBIC 118.02 2.81 118.02 2.81 on on 2 WS-X6248-RJ-45 112.98 2.69 112.98 2.69 on on 3 WS-X6516-GBIC 142.80 3.40 142.80 3.40 on on 4 WS-X6502-10GE 138.60 3.30 138.60 3.30 on on 5 WS-X6516A-GBIC 282.24 6.72 282.24 6.72 on on 6 WS-SUP720-3B 282.24 6.72 282.24 6.72 on on 7 WS-X6502-10GE 138.60 3.30 138.60 3.30 on on 8 WS-X6704-10GE 295.26 7.03 295.26 7.03 on on 9 WS-X6704-10GE 295.26 7.03 295.26 7.03 on on
