G703 Problem between Cisco VWIC-2MFT-G703 and Ericsson Minilink
Apr 29, 2005 0 Replies
Hi everybody,
This problem made me so confused. There are 14 stations connected (point to point) via Ericsson Minilink microwave systems. Minilink system provides n X 2Mbps channels with G.703 Interface. It seems that this should be the standard G.703 as the specifications given in Ericsson web site is:
Traffic interface: ITU-T Rec G.703 balanced or unbalanced Channel code: Screambling, and FEC Alarm interface: RS232C (V.24) Serial intreface
The current installed system has got 2 X 2Mbps and the 1st 2Mbps is used for Telecommunication purposes and we wanna to use the second
2Mbps channel for building a data network (TCP/IP). I used VWIC-2MFT-G703 Modules in Cisco 1721 to connect to the G703 Interface of the minilink. but unfortunately the link never goes up or goes up and down and there are lots of all kinds of line errors and violations on the line and also AIS is received from remote side. Here is a brief debug on the cisco. By the way, I tried all possible settings and configurations on the E1 Controllers without any satisfying result.
Your help in any kind, would be appreciated indeed.
Best Wishes N=2ER. Neshat BSc, CCNP, CCNA, Network+
debug: router02#sh controllers e1 0 E1 0 is down. Applique type is Channelized E1 - balanced Receiver is getting AIS. alarm-trigger is not set Version info Firmware: 20040202, FPGA: 11 Framing is UNFRAMED, Line Code is HDB3, Clock Source is Line Primary. Data in current interval (659 seconds elapsed): 31545 Line Code Violations, 0 Path Code Violations 1 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins 2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 1306 Unavail Secs router02#clear cout nt router02#sh controllers e1 0 E1 0 is down. Applique type is Channelized E1 - balanced Receiver is getting AIS. alarm-trigger is not set Version info Firmware: 20040202, FPGA: 11 Framing is UNFRAMED, Line Code is HDB3, Clock Source is Line Primary. Data in current interval (6 seconds elapsed): 29 Line Code Violations, 0 Path Code Violations 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 12 Unavai
------- router02#debug vwic-mft firmware controller e1 0 all vwic-mft firmware output messages for wic slot set to: Config Alarm FDL Loopback router02# router02#term mon router02#
*Mar 1 00:13:02.411: E1T1 0/1 FW: Clocking change: MASTER PORT:00
*Mar 1 00:13:02.411: E1T1 0/1 FW: cfg: clock: line/line
*Mar 1 00:13:02.415: E1T1 0/1 FW: set clocking E1, TE, Looped-Timed
*Mar 1 00:13:02.415: E1T1 0/1 FW: Clocking change: MASTER PORT:01
*Mar 1 00:13:03.771: E1T1 0/1 FW: cfg: clock: int/line
*Mar 1 00:13:03.771: E1T1 0/1 FW: set clocking E1, TE, Internal
*Mar 1 00:13:03.771: E1T1 0/1 FW: set clocking E1, TE, Looped-Timed
*Mar 1 00:13:03.771: E1T1 0/1 FW: Clocking change: MASTER PORT:00
*Mar 1 00:13:03.775: E1T1 0/1 FW: cfg: clock: line/line
*Mar 1 00:13:03.775: E1T1 0/1 FW: set clocking E1, TE, Looped-Timed
*Mar 1 00:13:03.775: E1T1 0/1 FW: Clocking change: MASTER PORT:01
*Mar 1 00:13:03.775: E1T1 0/1 FW: cfg: clock: int/line
*Mar 1 00:13:03.775: E1T1 0/1 FW: set clocking E1, TE, Internal
*Mar 1 00:13:03.779: E1T1 0/1 FW: Clocking change: MASTER PORT:00
*Mar 1 00:13:04.031: E1T1 0/1 FW: cfg: clock: int/line
*Mar 1 00:13:04.031: E1T1 0/1 FW: set clocking E1, TE, Internal
router02(config-controller)#clock source free router02(config-controller)#clock source free-running ?
router02(config-controller)#clock source free-running router02(config-controller)#^Z router02#
*Mar 1 00:14:35.219: %SYS-5-CONFIG_I: Configured from console by vty0 (192.168.101.2) router02# router02#debug wv  vw router02#debug vwic-mft contr router02#debug vwic-mft contr     ? firmware Debug firmware
router02#debug vwic-mft fi router02#debug vwic-mft firmware con router02#debug vwic-mft firmware controller e1 0 all vwic-mft firmware output messages for wic slot set to: Config Alarm FDL Loopback router02#
*Mar 1 00:15:20.899: E1T1 0/1 FW: cfg: clock: int/line
*Mar 1 00:15:20.899: E1T1 0/1 FW: set clocking E1, TE, Internal
*Mar 1 00:15:20.899: E1T1 0/1 FW: set clocking E1, TE, Looped-Timed
*Mar 1 00:15:20.903: E1T1 0/1 FW: Clocking change: MASTER PORT:00
*Mar 1 00:15:20.903: E1T1 0/1 FW: cfg: clock: ????/line
*Mar 1 00:15:20.903: E1T1 0/1 FW: set clocking E1, TE, Looped-Timed
*Mar 1 00:15:20.903: E1T1 0/1 FW: Clocking change: MASTER PORT:01
*Mar 1 00:15:20.903: E1T1 0/1 FW: cfg: clock: int/line
*Mar 1 00:15:20.903: E1T1 0/1 FW: set clocking E1, TE, Internal
*Mar 1 00:15:20.907: E1T1 0/1 FW: set clocking E1, TE, Looped-Timed
*Mar 1 00:15:20.907: E1T1 0/1 FW: Clocking change: MASTER PORT:00
*Mar 1 00:15:21.319: E1T1 0/1 FW: cfg: clock: int/line
*Mar 1 00:15:21.319: E1T1 0/1 FW: set clocking E1, TE, Internal
