frame-relay adaptive-shaping
Jul 19, 2005 3 Replies
Jump to replies (3)
Hi guys,
I must substitute an 805 (running 12.0.4) with a 3620 (with 12.3.13a) with a serial connector. I had to move all frame relay-parameters from one section to the other.
Moving frame-relay map-class new IOS doesn't accept the command "no frame-relay adaptive-shaping" because it wants more details.
As I don't know anything about frame-relay but I would know the command equivalent to that above.
Thanks,
Alex.
Hi Alex
no frame-relay adaptive-shaping {becn | foresight | interface-congestion}
view current config to see which options you need to negate.
Extra info
becn = Backward Explicit Congestion Notification becn is recieved if any queue in the frame-relay cloud exceeds a predefined level and the router will back off transmission speed.
foresight = a Cisco proprietry congestion avoidance system. Where BECN is used to respond to actual congestion, foresight is used to avoid congestion in the first instance. If a PVC is heavily used foresight will ask it to back off. If a PVC is lightly used foresight will let it continue. BECN on the other hand is indiscriminate.
interface congestion - works only with local interface congestion where BECN/Foresight work over the whole frame relay Cloud.
N.B. Foresight might not be available even using Cisco kit throughout the cload. It is rarely forwarded from a public backbone (if ever?) even when the backbone uses it.
I have included the above info as you stated you did not understand frame-relay operation. I hope you find it useful.
regards
Toby
Hi Alex
Extra info
regards
Toby
Hi Toby,
as when I write "no frame-relay adaptive-shaping" followed by each option the router doesn't display anything in "sh run" I think that that is the default so there is no needing to specify the statement "no frame-relay adaptive-shaping" as it is the default.
Thanks for you detailed explanation.
Alex.
