Frame Relay fragmentation and interleaving
May 11, 2006 2 Replies
I'm reading conflicting info regard frame-relay fragmentation and interleaving of packets. According to Cisco documentation, if frame-relay traffic shaping is enabled when using fragmentation, even when LLQ is used for providing the priority queue, interleaving will not occur. Is that the case? Also, when using FRF.12, the sample configs in the Cisco docs show the fragmentation configured on the interface. Could the fragmentation be configured in the map-class, along with the application of the LLQ policy-map, and still get the same results?
Thanks in advance,
Mikey
What are you trying to accomplish or is this an academic question? Unless your port speed is less than 128k, there is no need to implement interleaving or fragmentation.
Scott
