Frame-relay map and inverse-arp
Feb 10, 2005 6 Replies
Jump to replies (6)
Hi Group,
Under Configuring Static Address Mapping in
says, "A static map links a specified next-hop protocol address to a specified DLCI. Static mapping removes the need for Inverse ARP requests; when you supply a static map, Inverse ARP is automatically disabled for the specified protocol on the specified DLCI."
However, I lab this up and it does not seem to be the case. Can anyone clarify why? I thought it's the IOS version but I am using
12.2.
Thanks in advance.
Al
I used a hub and spoke topology. Here's my relevant configurations.
Hub
interface Serial0 ip address 192.168.1.1 255.255.255.0 encapsulation frame-relay no fair-queue
Spoke1 interface Serial0 ip address 192.168.1.2 255.255.255.0 encapsulation frame-relay no fair-queue frame-relay map ip 192.168.1.3 201
Spoke2 interface Serial0 ip address 192.168.1.3 255.255.255.0 encapsulation frame-relay no fair-queue frame-relay map ip 192.168.1.2 301
I rebooted Spoke1. Inverse arp to the Hub should be disabled but it isn't as seen below.
spoke1#show frame-relay map Serial0 (up): ip 192.168.1.1 dlci 201(0xC9,0x3090), dynamic, broadcast,, status defined, active Serial0 (up): ip 192.168.1.3 dlci 201(0xC9,0x3090), static, CISCO, status defined, active
I cleared the table and inverse arp disappeared as can be seen below. r1#clear frame-relay inarp r1#show fram r25031#show frame-relay map Serial0 (up): ip 192.168.1.3 dlci 201(0xC9,0x3090), static, CISCO, status defined, active
However, after I rebooted dynamic connection to the hub came back. spoke1#show frame-relay map Serial0 (up): ip 192.168.1.1 dlci 201(0xC9,0x3090), dynamic, broadcast,, status defined, active Serial0 (up): ip 192.168.1.3 dlci 201(0xC9,0x3090), static, CISCO, status defined, active
The same holds to spoke2.
You need to tell each interface what its dlci is with the frame-relay interface-dlci command.
sufficiently
> > It says,
automatically
I am using physical interfaces. I thought interface-dlci can only be used with subinterfaces. However, I stand corrected.
> It says,
On a second thought Spoke1-Spoke2 PVC seems not to be the case :-) What seems to be the case is that after reboot FR INARP first gets dynamic mapping and then later on gets disabled as it should be. Would You be able to "clear fame-relay inarp" and then wait sufficiently long (~1 hour) for dynamic mapping to reappear? If it doesn't reappear then it is definitely disabled :-) HTH, Cheers Alex
> It says,
Hello again, "frame-relay interface-dlci" command can be used on physical/multipoint interface, but it doesn't change the interface type. The main purpose for this command on phy/mpoint interface is to assign different FR traffic-shaping/class parameters to different DLCIs if there is more than one DLCI. FR switch normally advertises active DLCIs to routers via FR LMI "Status" messages so there should be normally no need to manually configure DLCIs with "frame-relay interface-dlci" command :-) HTH, Cheers Aelx
