Dwitching Eigrp to Rip
Oct 08, 2008 1 Replies
I have a static route setup on my network that is currently running eigrp.
This is currently going through to a router on ip 10.1.15.254 This also has eigrp and is redistributing the links.
I am now in the process of setting up a new internet connection and need this to go in to a firewall that can do rip or ospf
am I correct in thinking all I need to do is change the following
router eigrp 10 network 10.0.0.0 no auto-summary
to
router rip Network 10.0.0.0
Also can I use the 2 routing protocols for the same network or would this cause confusion.
Thanks
You can easily run both protocols, and I would consider turning up rip or ospf with the firewall only, and redistributing as needed between the protocols (don't generally recommend redistributing both ways though, instead just turn up that transit network in eigrp so it knows about it, and redistribute eigrp into rip or ospf).
