DNS problem using auth. with certificates
Aug 08, 2007 2 Replies
Can somebody help me. We have change solution for VPN users to logon to Cisco PIX, ver.6.3.5 using certificates and RSA Secure ID with tokens (requests are forwarded to external database from CISCO ACS ver.
4.1). All is running ok, connection and the rest, but when I check network configuration I can't see that I have DNS and WINS settings from CISCO VPN client. Same config is used but with group auth. instead certificates, also plus RSA SECURE ID, and that works great. I have latest CISCO VPN client and also try with several different but behavior's is the same. I'll appreciate some input. Thanks!
How do you mean "check network configuration" ? Is it on the client PC ?
Try a ipconfig /all from a command-box (run-cmd) HTH Martin
normally that I have used ipconfig /all to see what I have get.
