Direct Interconnecting Cisco Asyc
Jul 26, 2005 2 Replies
Hi all,
I've got two Cisco AS2511-RJ (16 Async Ports, amongst others).
Just for the hell of it, I want to configure the routers with a direct (crossover) link between an Asynch port on each router, similar to using a DTE-DCE crossover cable on synchronous ports.
I can find lots and lots of infor on configuring modems, PPP, etc. but little on doing a lab environment direct crossover.
Any ideas? Otherwise I guess I gotta break out a couple of modems and a PABX to fake the WAN Dial-up connection....
Thanks
use the console cable
router 1 Interface Async 65 ip address 192.168.1.1 255.255.255.0 encapsulation ppp async default routing async dynamic routing async mode dedicated
router 2 > Hi all,
for testing or maybe router access for admin but I would not use the built in AUX port for real data if much.
The built in AUX port can use a lot of CPU, Interupt heavy. However dedicated ASYNC modules are designed to offload the interupt traffic from the CPU.
