Dialer Idle Timeout Not Working
Jun 16, 2007 2 Replies
Can someone assist.
I'm trying to get a idle timeout working on interesting traffic port
27890 only. I can see Idle timeout dropping when user sending on this port and eventually will drop the line after 600 seconds. I only want the line to drop when not sending on 27890
is the below correct ? any help appreciated.
interface BRI0/0 ip address 10.10.2.50 255.255.255.0 ip access-group 101 in encapsulation ppp dialer idle-timeout 600 inbound dialer-group 1 isdn switch-type basic-net3 peer default ip address pool isdnpool ppp authentication chap ms-chap !
access-list 101 permit tcp 10.10.0.0 0.0.255.255 host 192.168.0.84 eq
27890 access-list 101 permit tcp 10.10.0.0 0.0.255.255 host 10.10.0.84 eq
27890 dialer-list 1 protocol ip list 101 no cdp run !
It might be correct, depending on your network topology. You don't give enough information to tell.
You can use debug dialer packet to see if your traffic is considered interesting or not. If it isn't, your configuration is wrong. If it is, something else is.
Hi Martin
Thanks for the reply.
will try the debug dialer.
The network is a simple.
One ethernet , One Bri port connected .
Pc is connected on Ethernet on 10.10.0.84 and listens on 27890.
Everything works and clients connect ok using ppp dialup. Just the IDLE timeout kicks them off after 600 seconds. Even during transfer of data on 27880/.
I suspect it could be old IOS causing this..
