QoS not working
Feb 26, 2007 2 Replies
I have follow QoS configuration on Cisco Access Point:
class-map match-all _class_testowa1 match access-group name testowywww class-map match-all _class_testowa0 match access-group name testowy
policy-map testowa class _class_testowa0 set cos 6 class _class_testowa1 set cos 0
ip access-list extended testowy permit ip any host 192.168.7.7 permit ip host 192.168.7.7 any permit tcp any any eq 443 deny ip any any
ip access-list extended testowywww permit ip any host 192.168.7.7 permit ip host 192.168.7.7 any permit tcp any any eq www deny ip any any
I only test but when I downloading something from 192.168.7.7:443 and
192.168.7.7:80 the speed on both is that same, about 60kbytes/s. I think the speed on :433 port should be much higher then on :80 port. I think the QoS not working:(
Am I right ?
Thanks Pawel R.
Your ACLs are the exact same as far as your traffic is concerned. Traffic will ignore the rest of the ACL once it matches a single line. Therefore, you want something like the following:
ip access-list extended testowwwy permit tcp 192.168.7.7 any eq 80
No need for deny, it is at the end of every ACL by default.
That's completely correct behavior. You are not limiting bandwidth - you are setting CoS (Class of Service) Layer2 marking on the frames. When they hit the router, if it set to honor CoS and convert it to DSCP, then it will be in the play. Also, your next router should be set up to limit or prioritize traffic based on CoS or DSCP. However even with all that, if your pipe is empty, everyone will take whatever it requests.
Good luck,
Mike
------ Headset Adapters for Cisco IP Phones
