DECnet over GRE tunnel with FiberOptic leased-line
Mar 29, 2006 6 Replies
Jump to replies (6)
DECnet over GRE tunnel with FiberOptic leased-line open original image
Hi All,
I have a problem in tunneling DECNET traffic over GRE using FiberOptic leased-line as the media in the middle of the network.
DECNET terminal - router - layer3 switch - FiberOptic - layer3 switch - router - DECNET server
Although the DECNET packet is smaller the link mtu, I guess, I've try to enable tunnel PMTUD (tunnel path-mtu-discovery) and configure ip mtu
1476 in the tunnel interface.
Then I tried to modify the DF-bit using ip policy route-map in the tunnel interface. It still doesn't work.
Has anyone ever experience this problem?
Does it have something to do with the GRE Tunnel latency?
Regards, Sali
Is IP working over the GRE tunnel ?
Does CDP flow over the tunnel ?
Post a sanitized configs of both routers and the post the output from both routers for
  1. sh version
  1. sh decnet
  2. sh decnet interface
  1. sh decnet route
  2. sh decnet nei
Are Decnet hellos being exchanged over the tunnel ?
debug decnet adj
Do you have "decnet cost x" configured on tunnel interfaces ?
This wouldn't be LAT would it? That won't work (LAT) without configuring bridging on the tunnel. In the later IOS releases bridging isn't supported (but can be configured) on the GRE tunnel interface.
If it is LAT, then LAT to TCP protocol translation should be used
see Cisco doc
The only problem with that is it very resource intensive (memory and CPU) and it doesn't support LAST and LAVC (sp?). It does work very well.
Well if the OP is trying to run vax cluster traffic over the Internet then all bets are off ...
