Tough PMTUD nut to crack
May 17, 2005 1 Replies
I've got an MTU-related problem for which I can't seem to find any good solutions. I've got two Cisco routers (both 3640s) at two different sites with a GRE tunnel between them. The GRE tunnel is being encapsulated via IPSEC by two PIXes that sit between the two routers. The routers are running IOS 12.3(12a) and the PIXes are on 6.3.3, if it matters. This is the basic diagram:
R1 PIX1 PIX2 R2
Generally speaking, hosts behind R1 perform large transfers to hosts behind R2, so R2 is usually receiving traffic.
So here's the problem: if I don't turn on "tunnel path-mtu-discovery" on the GRE tunnel, R2's CPU will frequently be pegged at 100% as it reassembles fragmented packets from the tunnel. But if I *do* turn on "tunnel path-mtu- discovery", scp transfers that are initiated by a Solaris host behind R1 to hosts behind R2 will sometimes, *but not always*, hang. Maybe one transfer out of several hundred will hang in this way. When the connections hang, they stay alive for the length of tcp_keepalive_interval, at which point the scp transfer finally fails (with a "Connection reset by peer" message).
I've tried many, many different things to address this:
1) Lowering the MTU on the GRE interfaces on the Cisco routers (I've tried many different settings, as far down as 1320 on each side)
2) Lowering the MTU on the Solaris host
3) Changing tcp_mss_def_ipv4 on the Solaris host
4) "ip tcp adjust-mss" on the GRE interfaces on the Cisco routers
Etc, etc. Nothing helps. Unfortunately, I've been unable to reproduce this problem in a controlled fashion (by running a test script on the Solaris box that just does scp transfers in an infinite loop), nor have I been able to determine if it's specific to Solaris or might affect other hosts as well.
So at this point I'm stuck with either a) a router whose CPU is constantly being pegged, or b) cron jobs that spew out 5-10 error emails a day, thanks to scp transfers that hang between the Solaris host and other hosts.
Any ideas?
Just in case, this is the tunnel configuration on Router1 (currently):
interface Tunnel0 description GRE tunnel to Router2 bandwidth 100000 ip address 10.1.2.3 255.255.255.252 ip mtu 1476 ip ospf message-digest-key 1 md5 7 deadbeef ip ospf cost 20 tunnel source Loopback1 tunnel destination 192.168.10.3 tunnel path-mtu-discovery
- John
It'd be really good to know exactly what's causing the session hang, but that can be a challenge. Running "snoop" on each endpoint (or tcpdump, ethereal, etc.) would probably be a good start. However, if setting the MTU down on each endpoint to a sufficiently small number didn't fix it, I'd suspect the problem is not really MTU related. Here's a very good white paper at Cisco that will tell you perhaps more than you ever wanted to know about PMTUD, and will help you pick good MTU values:
I'd also check the various interface stats in the involved devices (both tunnel and physical interfaces) for errors and/or drops, sine maybe something else is going on. Are you seeing any OSPF issues across the tunnel? Maybe it's a routing issue. As a test you could put some static routes in the routers to eliminate that possibility.
HTH - Good luck!
John Caruso wrote:
