Correct match with Juniper P-4OC3-SON-SMIR?
Apr 04, 2006 4 Replies
Merv
The Cisco PA-A1-OC3SM is an ATM port adapter If the link is Packet-over-SONET (POS) then the the correct Cisco part might be a PA-POS-OC3 depending on what your router model is ... Some of these Cisco PA are EOS/EOL so double check I would read the Junipter part number to be a…
We need to turn up an OC-3 with a provider running a Juniper M40 SMIR card, Part # P-4OC3-SON-SMIR.
Am I correct that a Cisco PA-POS-OC3 is the appropriate choice on our end, and not PA-A1-OC3SM, given the Juniper card at the other end?
Thanks in advance for the advice.
I would read the Junipter part number to be a 4 port OC3 SONET single-mode intermediate reach card
Thanks, that is what I was thinking, and why I did not think the ATM card was appropriate. The guys at the other end are die-hard Juniper and aren't (able | willing) to offer Cisco purchasing recommendations.
Yes, you are correct.
Steinar Haug, Nethelp consulting, snipped-for-privacy@nethelp.no
