Cisco softphone connection to ccm via pix split tunneling
Apr 14, 2006 2 Replies
I am trying to get my softphone to work via cisco's vpn client through my pix with split-tunneling enabled. The problem I am having is the softphone is registering to the ccm with the vpn pool ip assigned. I can make a call but there is not audio. I am using pix 515e ver 7.0. I am connecting via the internet to the pix. Any help would be greatly appreciated.
I had a friend with the same problem... He got tired of dealing with it so he removed the fixups and it started working... Not saying to do that but it's a good place to start your search....
I found the problem! The problem is not with the pix or split tunneling. The problem was in the ip communicator software under preferences> audio> Network...> My Audio ip address was set to Detect automatically. I changed it to Use this adapter's address (my nic). After that the audio was working just fine.
