split tunneling
May 31, 2005 2 Replies
Dear All
I am trying to setup split tunneling for our VPN Users at work. I feel my config is correct but I does not work. I was looking for some feedback and maybe what I might be missing. I have pasted the relevant parts of my config below. If you require anymore pls let me know.
Best Regards
Bhavesh
vpngroup ITIVPN address-pool vpnpool1
vpngroup ITIVPN dns-server 199.100.1.31 199.100.1.33
vpngroup ITIVPN default-domain ITI-AB.com
vpngroup ITIVPN split-tunnel ITIVPN_splitTunnelAcl
vpngroup ITIVPN split-dns iti.arabbank.plc arabbank.plc
vpngroup ITIVPN idle-time 1800
vpngroup ITIVPN max-time 1800
vpngroup ITIVPN password ********
access-list ITIVPN_splitTunnelAcl permit ip any any
access-list ITIVPN_splitTunnelAcl permit ip ITI 255.255.255.0 any
access-list ITIVPN_splitTunnelAcl permit ip 10.100.100.0 255.255.255.0 any
How are you trying to split up the VPN access? To separate out what is in work's IP range and everything else?
In article , BHAVESH PATEL wrote: :I am trying to setup split tunneling for our VPN Users at work. I feel my :config is correct but I does not work.
As you likely noticed, you did not get very many answers :-(
Your configuration appears to be that of a Cisco PIX. You are more likely to get PIX answers in the group comp.dcom.sys.cisco .
permit ip any any in a split-tunnel ACL tells the PIX that all IP traffic from anywhere to anywhere must be "protected" -- that is, must go through the tunnel. That leaves the following lines redundant and indeed you might as well not even specify split-tunnel in that case since you are instructing that you do not want anything allowed to go unprotected.
