Add split tunneling to my vpn group on PIX 515?
Jan 01, 2006 1 Replies
response3
Can you post your config? There's not much to it, you just need to make sure that your config has some form of the following: access-list roam_vpn_split_tunnel standard permit 192.168.xxx.0 255.255.255.0 ... group-policy roaming_vpn attributes ... split-tunnel-policy…
Hey. I had this working, but i went into asdm, and accidentily put inheret on my group policy, and i lost local lan access when connected to my lan. i dont know what command i need to re-enable this. can you tell me? It is a pix 515e. The vpn group is mountainbilling.
Thanks Jason
255.255.255.0 ... group-policy roaming_vpn attributes ... split-tunnel-policy tunnelspecified split-tunnel-network-list value roam_vpn_split_tunnel
Brian
