Cisco 501 PIX port forwarding (outside DHCP)
Sep 24, 2006 2 Replies
Hello,
I am trying to switch from a Cyberguard 570 to a Cisco 501 PIX. The PIX I have read about creating a forwarding rule but they all centered around a static external IP. IE something like this: static (inside,outside) tcp netmask 0 0
however how would I create this rule with a DHCP assigned external IP address?
Also the access-list would need to be created as well from what I understand...would that be something like this?
access-list
or in my case specifically
access-list torrents permit tcp
7684 192.168.1.100 7684
I guess overall my question is how to identify a DHCP assigned external interface IP address in these rules.
I recommend comp.dcom.sys.cisco for PIX questions.
static (inside,outside) tcp interface OUTSIDEPORT INSIDEADDRESS INSIDEPORT netmask 255.255.255.255 0 0
For outside access to inside,
access-list torrents permit tcp any interface outside eq 7684 access-group torrents in interface outside
You cannot explicitly do so, but you can use the keyword 'interface' in 'static' and the keyword 'interface outside' in ACLs.
