Cisco IOS 12.3(15) IP plus
Aug 25, 2006 5 Replies
Jump to replies (5)
Hi
How can I tell if IP plus is installed on a Cisco 2610 router running IOS 12.3(15)?
Output of show ver is below -
Cisco Internetwork Operating System Software
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(15), RELEASE SOFTWARE (f
c3) Technical Support:
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 24-May-05 14:02 by ssearch
Image text-base: 0x80008098, data-base: 0x81A13050
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-IK9O3S3-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
Router uptime is 9 minutes System returned to ROM by power-on System image file is "flash:c2600-ik9o3s3-mz.123-15.bin"
cisco 2610 (MPC860) processor (revision 0x203) with 61440K/4096K bytes of memory . Processor board ID JAD054005ZJ (1988650851) M860 processor: part number 0, mask 49 Bridging software. X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
Thanks Dilan
Hi Dilan, You can tell the feature set of your router based on the letters in the .bin file. Your IOS is "flash:c2600-ik9o3s3-mz.123-15.bin" the ik9o3s3-mz is your feature set. This feature set is IP/FW/IDS PLUS IPSEC 3DES BASIC. This is more enhanced then the IP/PLUS feautre set. If you have a CCO account with cisco, there are tools to compare/contrast the individual features of each IOS.
Thanks, Jon
snipped-for-privacy@gmail.com wrote:
The info is in the filename
c2600-ik9o3s3-mz is for IP/FW/IDS IPSEC 3DES BASIC
This may help
That's very nice, thanks.
One small thing c2600-ik9o3s3-mz
-mz m = Run from RAM z = Zip compressed
Some images run from flash (2500 router, few others IIRC) This is important when doing upgrades. e.g. How do you upgrade the running image?
This "unzip" for example uncompresses the image.
Y:\\>unzip -v UnZip 5.42 of 14 January 2001, by Info-ZIP. Maintained by C. Spieler. Send bug reports to the authors at snipped-for-privacy@lists.wku.edu; see README for details.
Latest sources and executables are at ftp://ftp.info-zip.org/pub/infozip/ ; see ftp://ftp.info-zip.org/pub/infozip/UnZip.html for other sites.
Thanks everyone, appreciate it.
