Help with a command
Aug 25, 2006 2 Replies
Hi all,
crypto map testmap local-address FastEthernet0/0
We have a router in India, the usual set up, they have a T1 to their provider with a serial ip address and behind that, they have an ethernet network with a small ip block.
I want to do a ipsec vpn tunnel to a firewall here in the US, and ofcourse I want it to work, so is it correct to use FastEthernet or should I have used Serial0/0/0 something? I want the traffic coming from their LAN encrypted.
A side question: Once this is working and the config on the firewall is fine, do you have to "open" the tunnel? how does it work?
Thanks,
-John
Help with a command open original image
Hi all,
Thanks,
-John
list of crypto configuration examples:- IPSec on Router to Router
Manual Keying Between Routers Configuration Example
Should get you going. There is no NAT here but you do not seem to want that.
