cisco experts pls answer these questions
Oct 16, 2006 2 Replies
cisco experts pls answer these questions open original image
  1. would a router configured as a stub establish neighbor relationship with a totally stubby router? (i.e. start exchanging routing information)
  1. rip v2 by default supports discontigous subnets and vlsm or does not support?
  2. is-is lsp packets lifetime is 15 mins or 20 mins?
  1. when you create an eigrp manual summary address, a route is created sourcing from or pointing to null0? in the show ip route command issued in the eigrp neighbor how many summary routes are seen (2?), the manual summary address and the automatic summarized summary address?
thanks!
Why not try and answer these yourself first.
I didn't know the answer to #3 but a quick Google search tells me that one of those times is the refresh interval and the other is how long the LSP's remain in the database without being refreshed. It's not that hard and is so much more rewardiung than simple having someone tell you the answer.
BernieM
Here is a great answer
You might have to do a search, but I know the answer to number 2 and 1 and found the answer to 3 and 4 in five minutes..so I think a good half hour of searching on cco might get your all your answers with details and you might learn a lot more in the hunt
Cheers
-------- Original Message --------
