Cisco ASA 5510
Sep 26, 2006 0 Replies
Hi I need help,
I have the following
1 x dlink dsl router, pppoa connection to outside world.
1 x ASA 5510
1 dlink attached to the asa
1 switch attached to the asa
the inside lan ip range is from 10.xx.xx.xx/24 the interface of the dlink is 10.10.1.1
I would like to permit all traffic inbound and outboud from the dlink into the asa and out through the lan interface.
Also with NAT and vpn from the dlink to the lan
I have a pppoa conenction BT on the Dlink then on the internal interface I have the ip address 10.0.0.3.
I can not get anything to go anywhere and do not really know why, I really hope someone can help.
I have enclosed my config for anyone to chekc and help, I am stuck and do not really know where to go.
names name 10.0.0.0 lan dns-guard ! interface Ethernet0/0 speed 100 duplex full nameif outsidedlink security-level 0 ip 10.10.1.1 255.255.255.0 ! interface Ethernet0/1 speed 100 duplex full nameif insideswitch security-level 0 ip address 10.0.0.4 255.255.255.0 ! interface Ethernet0/2 shutdown no nameif no security-level no ip address ! interface Management0/0 nameif management security-level 100 ip address 10.31.0.1 255.255.255.0 management-only ! ftp mode passive dns domain-lookup outsidedlink same-security-traffic permit inter-interface object-group network langroup description lan network-object lan 255.255.255.0 pager lines 24 logging enable logging asdm informational mtu outsidedlink 1500 mtu insideswitch 1500 mtu management 1500 ! no asdm history enable arp timeout 14400 nat (management) 0 0.0.0.0 0.0.0.0 rip outsidedlink passive version 1 rip outsidedlink default version 1 rip insideswitch passive version 1 rip insideswitch default version 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute http server enable http 10.31.0.0 255.255.255.0 management no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart sysopt noproxyarp outsidedlink sysopt noproxyarp insideswitch telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd address 10.31.0.2-10.31.0.254 management dhcpd lease 3600 dhcpd ping_timeout 50 dhcpd enable management !
