cisco asa 5510 secondary ip address
Mar 26, 2008 1 Replies
Hi all
How add secondary ip address on cisco asa ?
ip address 20.20.20.1 255.255.255.0 standby 20.20.20.2 secondary ? :)
there is another way to set a few address to interface ?
best regards ted
| How add secondary ip address on cisco asa ? | | ip address 20.20.20.1 255.255.255.0 standby 20.20.20.2 secondary ? :) | | there is another way to set a few address to interface ?
According to cisco you can not do this:
However you might try this and see if it works:
Also if you have a Layer 3 switch you can create subinterfaces on the ASA for the networks you need.
