logging on ASA 5510
Mar 25, 2008 1 Replies
Hi All
I have some problem:
I'd like set logging to my syslog in that way:
notification -> send to local.2 in syslog
now i configure : logging trap notification, but the traps are send to local4 or with flag local4. I can't change it to another localx.
thx for clue
best regards Ted
lookup up logging facility command
To specify the logging facility used for messages sent to syslog servers, use the logging facility command in global configuration mode. To reset the logging facility to its default of 20, use the no form of this command.
logging facility
Syntax Description facility Specifies the logging facility; valid values are 16 through 23.
