Cisco AP1200 problems! All clients looses ip.
Apr 11, 2006 9 Replies
Jump to replies (9)
Hello,
We have a Cisco AP1200 network with 12 AP's and 15 klients roaming between them. The problem is that all 15 clients (cisco 350 cards) looses ip after 30
- 40 mins.
Clients need to be restarted in order to get the system back up. I have no idea where to start troubleshooting. The network works fine with only 4 clients up and running, roaming is ok and everything.
I will post my AP logs. I hope there is someone with more cisco knowledge that can help me out and guide me in the right direction. Thank you in advance!
AP4#sh log Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) Console logging: level debugging, 266 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: level debugging, 268 messages logged, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 219 message lines logged
Log Buffer (4096 bytes): tries, removing the client Apr 11 08:32:52.938: Client 000f.f84f.a69c failed: reached maximum retries Apr 11 08:32:57.512: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.194f.f2a0 Apr 11 08:32:57.512: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:33:05.416: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:33:16.238: %DOT11-4-TKIP_MIC_FAILURE_REPORT: Received TKIP Michael MIC failure report from the station 000e.35b3.cc6d on the packet (TSC=0x0) encrypted and protected by pairwise key. Apr 11 08:33:50.432: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:34:06.611: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Previous authentication no longer valid Apr 11 08:34:27.879: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Reassociated KEY_MGMT[WPA PSK] Apr 11 08:34:42.087: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Previous authentication no longer valid Apr 11 08:34:43.121: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:34:56.149: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.1950.06b0 Apr 11 08:34:56.149: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:35:19.226: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:35:37.325: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.194f.ecc0 Apr 11 08:35:37.325: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:35:56.176: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000e.35b3.cc6d Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:37:27.851: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Previous authentication no longer valid Apr 11 08:37:30.340: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:37:54.112: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.1950.06b0 Apr 11 08:37:54.112: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:42:28.831: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000e.35b3.cc6d Associated KEY_MGMT[WPA PSK] Apr 11 08:45:46.877: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:47:58.839: %DOT11-4-TKIP_MIC_FAILURE_REPORT: Received TKIP Michael MIC failure report from the station 000e.35b3.cc6d on the packet (TSC=0x0) encrypted and protected by pairwise key. Apr 11 08:50:04.779: %DOT11-4-TKIP_MIC_FAILURE_REPORT: Received TKIP Michael MIC failure report from the station 000e.35b3.cc6d on the packet (TSC=0x0) encrypted and protected by pairwise key. Apr 11 08:51:07.726: %DOT11-4-TKIP_MIC_FAILURE_REPORT: Received TKIP Michael MIC failure report from the station 000e.35b3.cc6d on the packet (TSC=0x0) encrypted and protected by pairwise key. Apr 11 08:51:12.889: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.194f.ecc0 Apr 11 08:51:12.889: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:53:08.739: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:53:47.975: %DOT11-4-MAXRETRIES: Packet to client
000c.f157.26cd reached max retries, removing the client Apr 11 08:53:47.975: Client 000c.f157.26cd failed: reached maximum retries AP4#
AP7#sh log Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) Console logging: level debugging, 156 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: level debugging, 158 messages logged, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 147 message lines logged
Apr 11 08:24:16.811: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.1950.2550 Apr 11 08:24:16.812: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:24:41.781: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:25:49.655: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.194f.f2a0 Apr 11 08:25:49.655: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:26:09.623: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:29:23.536: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.1950.2d10 Apr 11 08:29:23.536: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:31:04.614: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:32:07.574: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.194f.f2a0 Apr 11 08:32:07.574: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:32:20.452: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:33:50.452: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.1950.2d10 Apr 11 08:33:50.452: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:35:37.254: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:35:56.439: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000e.35b3.cc6d Associated KEY_MGMT[WPA PSK] Apr 11 08:39:34.143: %DOT11-4-TKIP_MIC_FAILURE_REPORT: Received TKIP Michael MIC failure report from the station 000e.35b3.cc6d on the packet (TSC=0x0) encrypted and protected by pairwise key. Apr 11 08:41:41.051: %DOT11-4-TKIP_MIC_FAILURE_REPORT: Received TKIP Michael MIC failure report from the station 000e.35b3.cc6d on the packet (TSC=0x0) encrypted and protected by pairwise key. Apr 11 08:42:28.656: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000e.35b3.cc6d Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:45:47.066: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.1950.2d10 Apr 11 08:45:47.066: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:51:12.873: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:53:08.469: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.1950.2d10 Apr 11 08:53:08.469: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:55:20.706: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:56:17.668: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.1950.2550 Apr 11 08:56:17.668: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:56:37.662: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:56:57.647: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.1950.2d10 Apr 11 08:56:57.647: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS AP7#
ap8#sh log Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) Console logging: level debugging, 246 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: level debugging, 248 messages logged, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 211 message lines logged
Log Buffer (4096 bytes): :52.051: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a749 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:29:54.801: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR3 000f.f84f.a749 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:31:27.316: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a749 Reason: Previous authentication no longer valid Apr 11 08:32:34.678: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a69c Authentication failed Apr 11 08:32:46.022: %DOT11-7-AUTH_FAILED: Station 000c.f157.26cd Authentication failed Apr 11 08:33:32.664: %DOT11-7-AUTH_FAILED: Station 000c.f157.26cd Authentication failed Apr 11 08:33:56.167: %DOT11-7-AUTH_FAILED: Station 000c.f157.26cd Authentication failed Apr 11 08:34:09.832: %DOT11-7-AUTH_FAILED: Station 000c.f157.26cd Authentication failed Apr 11 08:34:12.525: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:34:27.776: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.1950.2d10 Apr 11 08:34:27.776: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:34:56.045: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Reassociated KEY_MGMT[WPA PSK] Apr 11 08:35:19.219: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.1950.2d10 Apr 11 08:35:19.219: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:37:54.156: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:37:56.079: *** TKIP Replay[ucast q 4]: TA=000c.f157.26cd, RSC=0xC,TSC=0xB Apr 11 08:37:56.511: *** TKIP Replay[ucast q 4]: TA=000c.f157.26cd, RSC=0xE,TSC=0xD Apr 11 08:38:04.564: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.1950.2550 Apr 11 08:38:04.564: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:50:02.761: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:50:22.475: %DOT11-6-ROAMED: Station 000f.f84f.a6e6 Roamed to
0013.1950.20b0 Apr 11 08:50:22.475: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:52:14.515: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR3 000f.f84f.a749 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:52:36.653: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:52:57.659: %DOT11-4-MAXRETRIES: Packet to client
000f.f84f.a749 reached max retries, removing the client Apr 11 08:52:57.659: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a749 Reason: Previous authentication no longer valid Apr 11 08:53:02.605: %DOT11-4-MAXRETRIES: Packet to client
000f.f84f.a69c reached max retries, removing the client Apr 11 08:53:02.605: Client 000f.f84f.a69c failed: reached maximum retries Apr 11 08:53:03.878: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:53:39.899: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Previous authentication no longer valid Apr 11 08:53:49.849: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Previous authentication no longer valid Apr 11 08:53:53.775: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:55:26.746: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.1950.2f60 Apr 11 08:55:26.746: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS ap8#
AP9#sh log Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) Console logging: level debugging, 199 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: level debugging, 201 messages logged, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 176 message lines logged
Log Buffer (4096 bytes): eaving (or has left) BSS Apr 11 08:27:06.054: %DOT11-6-ROAMED: Station 000f.f84f.a749 Roamed to
0013.1950.06b0 Apr 11 08:27:06.054: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a749 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:30:01.581: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:31:03.823: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Reassociated KEY_MGMT[WPA PSK] Apr 11 08:31:04.601: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.194f.ecc0 Apr 11 08:31:04.601: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:31:17.887: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:31:22.749: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a69c Authentication failed Apr 11 08:31:23.256: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:32:00.028: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Previous authentication no longer valid Apr 11 08:32:01.376: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:32:07.562: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:32:20.407: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.194f.ecc0 Apr 11 08:32:20.407: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:32:46.866: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.1950.2d10 Apr 11 08:32:46.866: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:32:55.078: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Previous authentication no longer valid Apr 11 08:32:57.508: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Reassociated KEY_MGMT[WPA PSK] Apr 11 08:32:59.460: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a69c Authentication failed Apr 11 08:33:05.414: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.1950.2d10 Apr 11 08:33:05.414: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:33:23.855: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Previous authentication no longer valid Apr 11 08:42:19.955: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR3 000f.f84f.a749 Associated KEY_MGMT[WPA PSK] Apr 11 08:42:45.741: %DOT11-6-ROAMED: Station 000f.f84f.a749 Roamed to
0013.1950.20b0 Apr 11 08:42:45.741: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a749 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:50:28.534: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR3 000f.f84f.a749 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:52:14.554: %DOT11-6-ROAMED: Station 000f.f84f.a749 Roamed to
0013.1950.06b0 Apr 11 08:52:14.554: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a749 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:52:33.488: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a749 Authentication failed Apr 11 08:52:39.911: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:53:03.229: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Previous authentication no longer valid Apr 11 08:53:29.218: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed AP9#
ap10#sh log Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) Console logging: level debugging, 191 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: level debugging, 193 messages logged, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 176 message lines logged
Log Buffer (4096 bytes): ..26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 06:44:38.193: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 06:46:50.259: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.194f.f2a0 Apr 11 06:46:50.260: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 07:37:09.318: %DOT11-7-AUTH_FAILED: Station 000e.35b3.cc6d Authentication failed Apr 11 07:38:21.416: %DOT11-6-ROAMED: Station 000e.35b3.cc6d Roamed to
0013.194f.ecc0 Apr 11 07:40:11.705: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.194f.ecc0 Apr 11 07:45:58.386: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 07:47:41.543: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Previous authentication no longer valid Apr 11 07:48:00.571: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 07:49:11.495: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Previous authentication no longer valid Apr 11 07:53:25.712: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000e.35b3.cc6d Associated KEY_MGMT[WPA PSK] Apr 11 07:53:38.468: %DOT11-4-MAXRETRIES: Packet to client
000e.35b3.cc6d reached max retries, removing the client Apr 11 07:53:38.469: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000e.35b3.cc6d Reason: Previous authentication no longer valid Apr 11 08:06:40.477: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000e.35b3.cc6d Associated KEY_MGMT[WPA PSK] Apr 11 08:06:40.515: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000e.35b3.cc6d Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:19:22.924: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Reassociated KEY_MGMT[WPA PSK] Apr 11 08:24:16.809: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:24:41.799: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.194f.ecc0 Apr 11 08:24:41.799: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:26:31.261: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Previous authentication no longer valid Apr 11 08:26:32.393: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:31:02.026: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a749 Authentication failed Apr 11 08:31:03.816: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.194f.f2a0 Apr 11 08:31:03.816: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:38:04.776: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Reassociated KEY_MGMT[WPA PSK] Apr 11 08:39:05.084: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Previous authentication no longer valid Apr 11 08:39:05.545: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Associated KEY_MGMT[WPA PSK] Apr 11 08:52:36.524: %DOT11-6-ROAMED: Station 000c.f157.26cd Roamed to
0013.1950.06b0 Apr 11 08:52:36.524: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000c.f157.26cd Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:56:17.641: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-TR57 000f.f84f.a663 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:56:37.634: %DOT11-6-ROAMED: Station 000f.f84f.a663 Roamed to
0013.194f.ecc0 Apr 11 08:56:37.634: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a663 Reason: Disassociated because sending station is leaving (or has left) BSS ap10#
AP12#sh log Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) Console logging: level debugging, 347 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: level debugging, 349 messages logged, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 267 message lines logged
Log Buffer (4096 bytes): ..a6e6 Associated KEY_MGMT[WPA PSK] Apr 11 08:42:45.949: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR3 000f.f84f.a749 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:45:06.679: %DOT11-6-ROAMED: Station 000f.f84f.a6e6 Roamed to
0013.1950.2f60 Apr 11 08:45:06.679: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:45:26.675: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:45:56.770: %DOT11-6-ROAMED: Station 000f.f84f.a749 Roamed to
0013.1950.2f60 Apr 11 08:45:56.771: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a749 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:47:24.128: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:48:07.183: %DOT11-6-ROAMED: Station 000f.f84f.a69c Roamed to
0013.1950.2f60 Apr 11 08:48:07.183: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:49:10.310: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:49:19.843: %DOT11-6-ROAMED: Station 000f.f84f.a6e6 Roamed to
0013.1950.2f60 Apr 11 08:49:19.844: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:49:39.797: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:50:02.777: %DOT11-6-ROAMED: Station 000f.f84f.a6e6 Roamed to
0013.1950.06b0 Apr 11 08:50:02.777: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:50:13.156: %DOT11-6-ROAMED: Station 000f.f84f.a69c Roamed to
0013.1950.2f60 Apr 11 08:50:13.156: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:50:22.600: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:51:05.601: %DOT11-6-ROAMED: Station 000f.f84f.a6e6 Roamed to
0013.1950.2f60 Apr 11 08:51:05.601: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:52:19.122: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:52:33.823: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a749 Authentication failed Apr 11 08:52:39.866: %DOT11-6-ROAMED: Station 000f.f84f.a69c Roamed to
0013.194f.f2a0 Apr 11 08:52:39.866: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:54:27.547: %DOT11-6-ROAMED: Station 000f.f84f.a69c Roamed to
0013.1950.2f60 Apr 11 08:55:07.125: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a69c Authentication failed Apr 11 08:55:07.466: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:57:35.024: %DOT11-6-ROAMED: Station 000f.f84f.a69c Roamed to
0013.1950.2f60 Apr 11 08:57:35.025: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:59:16.560: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Associated KEY_MGMT[WPA PSK] Apr 11 09:01:50.252: %DOT11-6-ROAMED: Station 000f.f84f.a6e6 Roamed to
0013.1950.2f60 Apr 11 09:01:50.252: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Disassociated because sending station is leaving (or has left) BSS AP12#
ap13#sh log Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) Console logging: level debugging, 326 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: level debugging, 328 messages logged, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 304 message lines logged
Log Buffer (4096 bytes): Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Associated KEY_MGMT[WPA PSK] Apr 11 08:45:06.962: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:45:26.856: %DOT11-6-ROAMED: Station 000f.f84f.a6e6 Roamed to
0013.1950.20b0 Apr 11 08:45:26.856: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:45:56.724: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR3 000f.f84f.a749 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:47:24.416: %DOT11-6-ROAMED: Station 000f.f84f.a69c Roamed to
0013.1950.20b0 Apr 11 08:47:24.416: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:48:07.370: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:49:10.334: %DOT11-6-ROAMED: Station 000f.f84f.a69c Roamed to
0013.1950.20b0 Apr 11 08:49:10.334: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:49:19.866: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:49:39.727: %DOT11-6-ROAMED: Station 000f.f84f.a6e6 Roamed to
0013.1950.20b0 Apr 11 08:49:39.728: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:50:13.258: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:50:28.609: %DOT11-6-ROAMED: Station 000f.f84f.a749 Roamed to
0013.194f.f2a0 Apr 11 08:50:28.610: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a749 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:51:05.719: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 08:52:19.205: %DOT11-6-ROAMED: Station 000f.f84f.a69c Roamed to
0013.1950.20b0 Apr 11 08:52:19.205: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:53:01.457: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a69c Authentication failed Apr 11 08:53:40.759: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:53:52.835: %DOT11-4-MAXRETRIES: Packet to client
000f.f84f.a6e6 reached max retries, removing the client Apr 11 08:53:52.836: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Previous authentication no longer valid Apr 11 08:54:27.204: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Previous authentication no longer valid Apr 11 08:54:27.683: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 08:55:07.519: %DOT11-6-ROAMED: Station 000f.f84f.a69c Roamed to
0013.1950.20b0 Apr 11 08:55:07.519: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a69c Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 08:55:26.744: %DOT11-6-ASSOC: Interface Dot11Radio0, Station
000c.f157.26cd Reassociated KEY_MGMT[WPA PSK] Apr 11 08:57:35.025: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR2 000f.f84f.a69c Reassociated KEY_MGMT[WPA PSK] Apr 11 09:01:50.325: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6e6 Reassociated KEY_MGMT[WPA PSK] Apr 11 09:02:30.271: %DOT11-6-ROAMED: Station 000f.f84f.a6e6 Roamed to
0013.1950.20b0 Apr 11 09:02:30.271: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6e6 Reason: Disassociated because sending station is leaving (or has left) BSS ap13#
AP14#sh log Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) Console logging: level debugging, 38 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: level debugging, 40 messages logged, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 21 message lines logged
*Mar 1 00:00:04.092: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
Mar 1 00:00:04.093: %DOT11-4-LOADING_RADIO: Interface Dot11Radio0, loading the radio firmware (flash:/c1200-k9w7-mx.123-7.JA2/5101.img)
*Mar 1 00:00:07.052: %SYS-6-LOGGERSTART: Logger process started
Mar 1 00:00:07.054: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:07.125: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:07 UTC Fri Mar 1 2002 to 01:00:07 GMT Fri Mar 1 2002, configured from console by console.
Mar 1 00:00:08.188: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 00:00:08.278: %SYS-5-CONFIG_I: Configured from memory by console
Mar 1 00:00:08.278: %SYS-5-RESTART: System restarted -- Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(7)JA2, RELEASE SOFTWARE (fc1) Technical Support:
(c) 1986-2005 by Cisco Systems, Inc. Compiled Fri 18-Nov-05 12:43 by ssearch
*Mar 1 00:00:08.278: %SNMP-5-COLDSTART: SNMP agent on host AP14 is undergoing a cold start
Mar 1 00:00:08.313: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:09.008: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
Mar 1 00:00:09.297: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up Apr 11 05:29:08.730: %DOT11-6-ASSOC: Interface Dot11Radio0, Station TACTILE-NNNNX5 000f.f84f.a6d9 Reassociated KEY_MGMT[WPA PSK] Apr 11 05:29:28.679: %DOT11-6-ROAMED: Station 000f.f84f.a6d9 Roamed to
0013.1950.20b0 Apr 11 05:29:28.680: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6d9 Reason: Disassociated because sending station is leaving (or has left) BSS Apr 11 05:49:26.181: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:49:31.514: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:49:38.904: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:49:43.993: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:49:44.349: %DOT11-4-MAXRETRIES: Packet to client
000f.f84f.a6e6 reached max retries, removing the client Apr 11 05:49:44.349: Client 000f.f84f.a6e6 failed: reached maximum retries Apr 11 05:49:59.084: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:04.341: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:09.861: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:15.052: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:20.088: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:25.561: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:31.594: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:36.957: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:41.908: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:47.020: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:52.405: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:57.574: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:50:58.946: %DOT11-4-MAXRETRIES: Packet to client
000f.f84f.a6e6 reached max retries, removing the client Apr 11 05:50:58.946: Client 000f.f84f.a6e6 failed: reached maximum retries Apr 11 05:53:46.466: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:53:51.737: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 05:58:14.799: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 07:03:01.078: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed Apr 11 07:03:08.695: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6e6 Authentication failed AP14#
AP15#sh log Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) Console logging: level debugging, 11 messages logged, xml disabled, filtering disabled Monitor logging: level debugging, 0 messages logged, xml disabled, filtering disabled Buffer logging: level debugging, 13 messages logged, xml disabled, filtering disabled Logging Exception size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 16 message lines logged
*Mar 1 00:00:04.097: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
Mar 1 00:00:04.098: %DOT11-4-LOADING_RADIO: Interface Dot11Radio0, loading the radio firmware (flash:/c1200-k9w7-mx.123-7.JA2/5101.img)
*Mar 1 00:00:07.058: %SYS-6-LOGGERSTART: Logger process started
Mar 1 00:00:07.060: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:07.130: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:07 UTC Fri Mar 1 2002 to 01:00:07 GMT Fri Mar 1 2002, configured from console by console.
Mar 1 00:00:08.187: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 00:00:08.273: %SYS-5-CONFIG_I: Configured from memory by console
Mar 1 00:00:08.273: %SYS-5-RESTART: System restarted -- Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(7)JA2, RELEASE SOFTWARE (fc1) Technical Support:
*Mar 1 00:00:08.274: %SNMP-5-COLDSTART: SNMP agent on host AP15 is undergoing a cold start
Mar 1 00:00:08.309: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:09.006: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
Mar 1 00:00:09.293: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up Apr 11 06:09:08.262: %DOT11-7-AUTH_FAILED: Station 000f.f84e.9faf Authentication failed AP15#
You should upgrade the software, this JA2 is deferred.
So I should update to the latest available AP1200 firmware? Anyone know which version thos latest firmware is, and where to find it? The cisco site is not very userfriendly :( Thanks
12.3.8-JA or 12.3.7.JA3
Upgraded to 12.3.7.JA3, still locking the network if I run more than 5 clients. All my clients use the same user/pass auth. the networks windows 2003 server. Can this cause the problem? Maybe this is not a cisco issue?
Any advice?
Ignore the part of the same user/pass... We do not do any auth. against w2003 server. Only auth that is done is against the AP using WPA... Still welcome any advice!
Hi!
I have all my logs available at
would appriciate any possible guidelines :)
I have removed the first 2 ip fields for security reason since they can be reached over the internet. first two fields is replaced with *.*
Thank you
It appears that you are using basic 802.11F roaming (IAPP)
Questions
  1. Are all of the APs on the same IP subnet ?
  1. What client software version is being used with the 350 wireless cards ?
  2. Does the problem occur as soon as the 6th client associates or 30 to
40 minutes after the 6th client associates and every 30 to 40 minutes after that?
You might want to see if configuring "dot11 network-map" provides you any useful info via the "show dot11 network-map" command
Do you have two wireless workstations that have the same MAC address ?
Station SENYK-TAC-KR1 000f.f84f.a6dd
Station TACTILE-PPPW2 000f.f84f.a6dd
on AP14 there were numerous authentication failure messages for that MAC address
2006-04-12 11:14:45 Local4.Info *.*.181.114 20: Apr 12 09:14:44.987: %DOT11-6-ASSOC: Interface Dot11Radio0, Station SENYK-TAC-KR1 000f.f84f.a6dd Reassociated KEY_MGMT[WPA PSK] 2006-04-12 11:14:46 Local4.Debug *.*.181.114 21: Apr 12 09:14:45.129: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a69c Authentication failed 2006-04-12 11:15:18 Local4.Warning *.*.181.114 22: Apr 12 09:15:18.992: %DOT11-4-MAXRETRIES: Packet to client 000f.f84f.a6dd reached max retries, removing the client 2006-04-12 11:15:19 Local4.Info *.*.181.114 23: Apr 12 09:15:18.992: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000f.f84f.a6dd Reason: Previous authentication no longer valid 2006-04-12 11:15:51 Local4.Debug *.*.181.114 24: Apr 12 09:15:50.144: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:15:56 Local4.Debug *.*.181.114 25: Apr 12 09:15:55.735: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:16:02 Local4.Debug *.*.181.114 26: Apr 12 09:16:01.860: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:16:08 Local4.Debug *.*.181.114 27: Apr 12 09:16:07.467: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:16:14 Local4.Debug *.*.181.114 28: Apr 12 09:16:13.924: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:16:20 Local4.Debug *.*.181.114 29: Apr 12 09:16:19.223: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:16:25 Local4.Debug *.*.181.114 30: Apr 12 09:16:24.335: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:16:30 Local4.Debug *.*.181.114 31: Apr 12 09:16:29.734: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:16:35 Local4.Debug *.*.181.114 32: Apr 12 09:16:34.922: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:16:41 Local4.Debug *.*.181.114 33: Apr 12 09:16:40.173: %DOT11-7-AUTH_FAILED: Station 000f.f84f.a6dd Authentication failed 2006-04-12 11:17:00 Local4.Info *.*.181.114 34: Apr 12 09:16:59.091: %DOT11-6-ROAMED: Station 000f.f84f.a6dd Roamed to 0013.1950.2f60
What about these timeouts? dot11 activity-timeout unknown default 1800 dot11 activity-timeout client default 1800 dot11 activity-timeout repeater default 1800 dot11 activity-timeout workgroup-bridge default 1800 dot11 activity-timeout bridge default 1800
