Needing direction
Oct 11, 2006 0 Replies
I have a wireless network in my house that is served up by a Linksys WRT54G router. I live in a rural area without DSL or cable, so the internet connection to my house is served up by an ISDN line and a Netopia R3100 series router which feeds the WRT54G.
Our two wireless enabled laptops see the wireless network OK, and I can ping/telnet/ftp/tracert out to destinations on the web such as
, etc. However, when I open a browser session (either Internet Explorer or Firefox) to
, the browser churns away for a while and then throws up a page not found error. I try this for
, and any other common web address and I get the same result.
While the browser is trying to materialize the page, I do a netstat and I see an entry with Google's IP address like so:
64.233.179.104:http ESTABLISHED
However, the browser never presents the web page.
Other oddities:
I can update my Ad-Aware software from the web, but Spy-bot will not update. Also, I can try for 30-40 minutes to get out with the browser with no luck, then leave my PC for a day or so (no reboot), and try again and the browser works, leave for a couple of hours, and the browser doesn't work. When the browser is down, my Cisco VPN client does not work, but if the browser works, I can VPN to my office.
Sometimes, I *THINK* I can kickstart the browser by going in and changing the subnet mask on the ISDN router to any value in the range
255.x.x.x and that may work for a while, but then again, the browser stops working at some later point.
I have tried using IE browsers on two wireless laptops: a Dell running Win XP Pro, and an older Compaq Presario running XP Home. Both have the same problem
I have also tried this on my home brew desktop running XP Pro with IE and Firefox, and tried it with the machine both physically plugged into the wireless router and/or the Netopia ISDN router, but the results are the same.
I thought maybe my browser or port may have been hijacked, so, I have run virus scans, ad-aware scans, spy-bot scans, cwshredder, you name it, but nothing seems to work.
I have been running the ISDN/WRT54G scenario for about 3 years now, but the Netopia has ony been in the mix for about the last 6 months, and this problem started about 2 months ago.
Has anybody had a similar situation where their browser just stopped working, but every other port connection to the internet still seemed to work?
