Cisco 877 & DHCP not excluding addresses
Jul 03, 2006 1 Replies
Hi all A strange one we can't quite put our finger on
ip dhcp excluded-address 192.168.1.1 192.168.1.49 ip dhcp excluded-address 192.168.1.101 192.168.1.254
ip dhcp pool CLIENT import all network 192.168.1.0 255.255.255.0 default-router 192.168.1.1 dns-server 218.214.17.1 202.154.83.53 lease 0 2
When we do a sh ip dhcp pool CLIENT
Pool CLIENT : Utilization mark (high/low) : 100 / 0 Subnet size (first/next) : 0 / 0 Total addresses : 254 Leased addresses : 0 Pending event : none 1 subnet is currently in the pool : Current index IP address range Leased addresses 192.168.1.1 192.168.1.1 - 192.168.1.254 0
All addresses are present, we should only be seeing a range of
192.168.1.50 to 192.168.1.100
Any suggestions would be welcome
Scott
I suggest that:- sh ip dhcp pool Does not bother with the exclusions?
Maybe you would like it to, maybe it should? It doesn't on routers here either.
If you have documents that say it should please post a link.
