Cisco 871w + WEP + VLans
Mar 02, 2006 2 Replies
Here is my dilema. I have a cisco 871w with two SSID's. One SSID is bridged to the ethernet switch so it can communicate with a wired network. The other is just bridged to the wan port of the cisco. Each are vlans. I want to do open auth and wep on both SSID. but when I enter the wep key the cisco changes the key in the config totally even makes it a 28 char key instead of 26 I assume this is some kind of encryption. Well my wireless clients can associate with the router but cannot connect to the network. With encryption off everything works great. my config is attached.
version 12.3 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname cameo ! boot-start-marker boot-end-marker ! logging buffered 51200 debugging logging console critical enable secret 5 ! username admin privilege 15 secret 5 clock timezone PCTime -5 clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00 no aaa new-model ip subnet-zero no ip source-route ip cef ip dhcp excluded-address 192.168.5.1 192.168.5.4 ip dhcp excluded-address 192.168.5.251 192.168.5.254 ! ip dhcp pool GEPDHCP import all network 192.168.5.0 255.255.255.0 domain-name cybermind-usa.net dns-server 65.161.0.135 65.161.0.136 default-router 192.168.5.1 ! ip dhcp pool CameoWireless import all network 192.168.6.0 255.255.255.0 domain-name cybermind-usa.net dns-server 65.161.0.135 65.161.0.136 default-router 192.168.6.1 ! ! ip tcp synwait-time 10 no ip bootp server ip domain name cybermind-usa.net ip name-server 65.161.0.135 ip ssh time-out 60 ip ssh authentication-retries 2 no ftp-server write-enable ! ! ! ! ! bridge irb ! ! interface FastEthernet0 no ip address no cdp enable ! interface FastEthernet1 no ip address no cdp enable ! interface FastEthernet2 no ip address no cdp enable ! interface FastEthernet3 no ip address no cdp enable ! interface FastEthernet4 description $FW_OUTSIDE$$ES_WAN$ ip address 192.168.2.20 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip virtual-reassembly ip route-cache flow duplex auto speed auto no cdp enable ! interface Dot11Radio0 no ip address ! encryption key 1 size 128bit 7 D10150216C72734100A238368974 transmit-key encryption key 2 size 128bit 7 6D61637372756C65746F8961793E ! encryption vlan 3 mode ciphers wep128 ! encryption vlan 2 mode ciphers wep128 ! ssid CMM vlan 3 authentication open ! ssid GEP vlan 2 authentication open ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0 station-role root no cdp enable ! interface Dot11Radio0.2 encapsulation dot1Q 2 ip address 192.168.5.1 255.255.255.0 ip nat inside ip virtual-reassembly no cdp enable ! interface Dot11Radio0.3 encapsulation dot1Q 3 ip address 192.168.6.1 255.255.255.0 ip nat inside ip virtual-reassembly no cdp enable ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$ no ip address bridge-group 1 ! interface BVI1 description $ES_LAN$ ip address 192.168.1.1 255.255.255.0 ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 ! ip classless ip route 0.0.0.0 0.0.0.0 192.168.2.1 ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 5 life 86400 requests 10000 ip nat inside source list 1 interface FastEthernet4 overload ! logging trap debugging access-list 1 permit 192.168.1.0 0.0.0.255 access-list 1 permit 192.168.5.0 0.0.0.255 access-list 1 permit 192.168.6.0 0.0.0.255 no cdp run ! control-plane ! bridge 1 protocol ieee bridge 1 route ip banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!^C ! line con 0 login local no modem enable transport preferred all transport output telnet line aux 0 login local transport preferred all transport output telnet line vty 0 4 privilege level 15 login local transport preferred all transport input telnet ssh transport output all ! scheduler max-task-time 5000 scheduler allocate 4000 1000 scheduler interval 500 end
snipped-for-privacy@gmail.com wrote: but when I
When you say the cisco changed the key, I assume you're talking about this part of the config. :
Yes, the Cisco router will encrypt what you type into the device, so that a person accessing the router, and looking at your config can not see what the actual key is, as an added security measure. Rest assured, however, that the router knows what the actual key is, and so the problem with your wireless clients has nothing to do with what you see in your config. Sorry I don't have an answer for you as to why your clients are having problems, but I hope this helps clear up the confusion.
BTW, if you configure an enable secret password on the router, it will do the same thing. Also, if you enter the command "service password-encryption" the same will hold true if you have passwords assigned to the Console, AUX and VTY lines.
You should be aware that the "7" method encryption can be trivially reversed using software available on the internet.
I have a few lines of Perl that does it nicely.
The "secret" or "5" method cannot be reversed as I understand it. The "7" method therefore provides protection from someone looking over your shoulder (in the case of most observers anyway) but provides no protection from someone who has access to the config files.
Hmmm! The above may not apply in the case here of the encryption key command. They do not reverse to anything nice looking. Maybe that's because that have been entered as hex?
