Cisco 851 reset baud rate
Jun 01, 2007 1 Replies
Does anybody know how to reset the baud rate on a Cisco 851? I've done jumper-resets on 2600s before, but I can't find any documentation for the 851.
When I console in, the "=E2=82=AC" symbol runs across the screen.
I'm sure my computer settings and cables are good because I can console into other Cisco routers just fine.
Thanks, hack.bac
You'd have to go back a bit further than the 2600 for a jumper change...
Just try each of the baud rates until you find the one it is. Then break and 'confreg' and change it back to the default.
