Cisco 837 - 12.4 - MRTG monitoring stopped?
May 23, 2006 1 Replies
Jim Willsher
Oops, my fault. 1:public should now be 5:public. The interface numbers seem to hve changed. All working now. Jim
Hi all,
I'm running 12.4 (7), having upgraded from 12.3(11).
Under 12.3 I used to monitor ATM (ADSL) and Ethernet throughput using:
Target[atm0]: 1:public@192.168.1.1: Title[atm0]: Cisco 837 - ADSL (ATM0)
and
Target[eth0]: 2:public@192.168.1.1: Title[eth0]: Cisco 837 - Ethernet (Eth 0)
Both these are now returning zeros.
Other values (such as sync rate) are returning correct data, albeit using slightly different OID values from before.
Is there a different way to do this in 12.4? If there's an OID can somebody suggest what it might be?
Many thanks,
Jim
Oops, my fault.
All working now.
Jim
