Cisco 837, 828 GRE tunnel
Jan 26, 2006 3 Replies
Jump to replies (3)
Do I require IP plus software to create GRE Tunnels on cisco 800 router platforms.
Thanks.
In article , wrote: :Do I require IP plus software to create GRE Tunnels on cisco 800 router :platforms.
On the 828, you need the PLUS feature set, either IP PLUS or IP/FW PLUS 3DES. On the 837, you need IP/FW/PLUS 3DES.
Sigh, the Feature Navigator is giving strange information again. (Surprising is when it's information is -accurate- :( )
According to the Feature Navigator, the choices are:
87x: ADVANCED SECURITY or ADV. IP SERVICES or ADV. ENTERPRISE SERVICES 85x: ADVANCED SECURITY or ADVANCED IP SERVICES 83x: IP/FW/PLUS 3DES 82x: IP PLUS or IP/FW PLUS 3DES
With "ADV. IP SERVICES" being different than "ADVANCED IP SERVICES" according to the Feature Navigator (and "ADV. ENTERPRISE SERVICES" being different than "ADVANCED ENTERPRISE SERVICES".)
Thanks for that. I thought you needed IP Plus, our data product manager didn't think so.
I'll assume that IP plus will work with GRE tunnelling across all 800 series routers.
cheers.
If I understand correctly, that is not the case: I believe the 87x in particular does not support IP PLUS . See the list I posted earlier.
