Cisco 831 Wan Port
Mar 23, 2008 6 Replies
Jump to replies (6)
Cisco 831 Wan Port open original image
Hello Is the "Wan Port" of the C831 autosensing for duplex-operation, and is it forced to 10mbit ?
Thank you
AFAIK the 8312 WAN port is 10 MBPS port only - i.e it is not 1 10/ 100 MBPS port
Are you having some type of problem ?
Do you have a console cable connected to the console port so that you can access router ?
If so post the output of the following commands:
show version
sho interface
Hello I haven't any problems yet :) I just want to know if I can use that in an unmanaged switch enveroniment avoding duplex-mismatch
for example some ETH interfaces of cisco 2600 and 1700 are not auto.duplex
the most important thing for me is that the 831 is MANAGEABLE (duplex operating mode)
If with a 12.4 it is exactly as the 837 (wich I have) I am not going to face any problems.
IIRC the 831 does support duplex auto
Perfect
because I may need to set the duplex on the eth port of the C831. I have a C837 with 12.4 IOS and I can set the duplex mode of every port. I think that the 831 can do the same.
Anyone here has a 831 so can confirm that?
Elia Spadoni schrieb:
You can set duplex on every Port of a 831 You can set speed 10/100 only on FastEthernet0-3 ports The WAN Port (Ethernet1) is a 10MBit/s only
For a connection of Ethernet1 with an unmanaged switch auto usually negotiates half-duplex with 10MBit/s. 10MBit/s and full-duplex is very uncommon and only works in very few combinations.
"Uli Link" ha scritto nel messaggio news:47e6a9b4$0$627$ snipped-for-privacy@newsspool1.arcor-online.net...
Well, the link in eth1 is not duplex-manageable? Can i set "duplex auto" ? If the switch is 10/100 and supports autosensing, it will negotiate 10 full.
I always use 10 full on my Cisco 261x in a managed switch, when both the router and the switch port is set to full duplex.
