Cisco 7970 gate control
Jan 10, 2008 3 Replies
Jump to replies (3)
Hi guys,
i need to integrate the 7970 Cisco IP phone using CME for the following function:
1- Intercom door alarm & voice integration with the villa gate.
2- The ability to open the door through the 7970.
I have searched online and could not find anyone implemented this solution.
Any ideas, or links will be highly appreciated.
Regards, Andy
There is a Cisco Phone SDK that you can examine to do this, but not sure if it is possible. I have used this for apps using CallManager, but not sure what is possible using CME.
I decided to search for SIP supported appliance, and i found a couple; one of them is CyberData, i am in the process to buy the door intercom and test it with CME.
I will keep you updated
Regards, Andy
Andy,
Have you used the CyberData SIP intercom yet? I'm thinking of getting one for my house to use with CME on a 2821 router, and was wondering what your experiences of it are?
Thanks, Matt
