[Cisco 1841] Being desperate with wireless config
Mar 25, 2008 0 Replies
hi guys,
I'm desperate in need of some help configuring my 1841 as a basic access point.
First let me explain what I need it for. I need to connect my laptop, using a wireless connection, to a device connected to one of the FE ports.
I see the SSID in my Windows connection manager, but I can't connect to the router. Als I think I need to set-up a route from the WIC to one of the F! ports.
Below My config file
Current configuration : 3889 bytes ! ! Last configuration change at 13:32:05 UTC Tue Mar 25 2008 by hwsound ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname yourname ! boot-start-marker boot-end-marker ! logging buffered 52000 debugging ! no aaa new-model ! resource policy ! ip cef ! ! ! ! ip domain name yourdomain.com ! ! crypto pki trustpoint TP-self-signed-2334219808 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-2334219808 revocation-check none rsakeypair TP-self-signed-2334219808 ! ! crypto pki certificate chain TP-self-signed-2334219808 certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101
04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D
43657274
69666963 6174652D 32333334 32313938 3038301E 170D3038 30333235
31333236
32335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504
03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32
33333432
31393830 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030
81890281
8100C78A 61BCD6F5 8DBD91A9 A111A49B 41CDFF92 D909FEA6 0AADACB5
7943ADEB
6CEFED5B 5691D6B1 74DEC5CF B7818A62 9B24D62C E93673FA 1F9D2BF0
0D07B034
307A1954 19379036 AA22C873 A7C43579 19EA41FC 0C90F8F7 F4401459
0BD63F09
057DB1A9 9557F7DC F01A1031 179BC736 61CFF0D9 33F6AA6E 71C2EDB5
5C683039
2E170203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF
30220603
551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E
2E636F6D
301F0603 551D2304 18301680 14A78FE8 A6242CC1 53A30227 F63AEDE4
7DD4231B
51301D06 03551D0E 04160414 A78FE8A6 242CC153 A30227F6 3AEDE47D D4231B51
300D0609 2A864886 F70D0101 04050003 818100BD CF261D62 7E3B537D
77FD1F91
4EFF569D 23989201 B19A4121 189574A4 AC7BB1E7 5A63D01B F6CEB012 CEC71577
41CD535F 8183607B 3438A1EA 55CF980F 8594FF2A 2C374A04 4063E371 AE5F77D2
24A87D95 A33E8ECA D5EBFF0E 570A90D8 C86B4607 42D69A59 D611623F
5F811855
1DE53817 12AACD4D A5CFC878 307525FF 0C24FD quit username hwsound privilege 15 secret 5 $1$1oIF$js0TWJbL8R/2eLelYeVxn/ ! ! ! bridge irb ! ! ! interface FastEthernet0/0 description $ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ETH-LAN$ ip address 192.168.1.120 255.255.255.0 duplex auto speed auto ! interface FastEthernet0/1 no ip address duplex auto speed auto bridge-group 1 ! interface Dot11Radio0/0/0 no ip address ! ssid HerrieWeb vlan 1 authentication open guest-mode ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0 station-role root ! interface BVI1 ip address 192.168.10.1 255.255.255.0 ! ! ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! ! ! ! ! control-plane ! bridge 1 protocol ieee bridge 1 route ip banner login ^CCCCCCC
----------------------------------------------------------------------- Cisco Router and Security Device Manager (SDM) is installed on this device. This feature requires the one-time use of the username "cisco" with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI. Here are the Cisco IOS commands.
username privilege 15 secret 0 no username cisco
Replace and with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START GUIDE for your router or go to
^C ! line con 0 login local line aux 0 line vty 0 4 privilege level 15 login local transport input telnet ssh line vty 5 15 privilege level 15 login local transport input telnet ssh ! scheduler allocate 20000 1000 end
