Cisco 1720 Capabilities and Config Help
Jan 08, 2006 2 Replies
I've got a Cisco 1720 router and 2 WIC 1-ENET's and IOS v 12.3 (not sure of the sub version, don't have the router in front of me) that I would like to setup as a dual WAN router. First I need to know if the
1720 will even do what I want with the IOS I have or if I need a new IOS or different router. Second I need some help with my config if I can do it. Below is what I'm trying to accomplish.
FastEthernet0 - Internal Network ip 192.168.30.1 providing DHCP to internal network
Ethernet0 - WAN ip DHCP (Connected to Cable Modem) Get next hop through DHCP Route all traffic through this interface except what's defined for Ethernet1
Ethernet1 ip 66.224.2.13 Next hop 66.224.2.1 Route all traffic destined for 66.224.2.0 Network through this interface
Here's my current config: I may be way off on this as this my first attempt at cisco routers.
! ! Last configuration change at 17:38:22 UTC Fri Jan 6 2006 ! NVRAM config last updated at 17:38:56 UTC Fri Jan 6 2006 ! version 12.3 service config service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname CWBENCH1 ! boot-start-marker boot-end-marker ! enable secret 5 enable password ! memory-size iomem 25 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 no aaa new-model ip subnet-zero ip cef ! ! no ip dhcp conflict logging ip dhcp excluded-address 192.168.30.1 192.168.30.20 ! ip dhcp pool benches network 192.168.30.0 255.255.255.0 dns-server 66.224.2.5 66.224.2.6 66.224.2.7 default-router 192.168.30.1 lease 0 1 ! no ftp-server write-enable ! ! ! ! interface Ethernet0 ip address dhcp ip nat outside half-duplex no cdp enable ! interface Ethernet1 ip address 66.224.2.13 255.255.255.0 ip nat outside half-duplex no cdp enable ! interface FastEthernet0 ip address 192.168.30.1 255.255.255.0 ip nat inside speed auto full-duplex no cdp enable ! router eigrp 1 network 66.0.0.0 auto-summary ! router eigrp 2 network 192.168.0.0 auto-summary ! ip nat inside source list 1 interface Ethernet0 overload ip nat inside source list 2 interface Ethernet1 overload ip classless ip route 66.224.2.0 255.255.255.0 Ethernet0 66.224.2.1 ip http server ! access-list 1 deny 66.224.2.0 0.0.0.255 access-list 1 permit any access-list 2 permit 66.224.2.0 0.0.0.255 access-list 2 deny any no cdp run snmp-server community CWISP RO ! line con 0 line aux 0 line vty 0 4 password login ! end
