Cisco 12000 Voltage calculation
Aug 08, 2006 4 Replies
Jump to replies (4)
Cisco 12000 Voltage calculation open original image
Hi There,
I=B4m having troubles calculating used and available voltage in the GSR=B4s of my company. It is very easy to get this information in a 7609 but not in a 12000.
The command I=B4m using is "show environment voltages" and I get some information I still cannot understand at all.
Does someone know how to calculate the available and used voltages in this kind of routers ?
Thanks.
Mauro
Have a look at ther power management command
show gsr power-mgr
Hi Mauro,
Adding to Merv's excellent suggestion you may wish to investigate:
show gsr power-mgr
The following example displays a summary of total power consumption and total power available:
router# show gsr power-mgr Power management summary
------------------------ Powershelf type: Intelligent AC Power Supplies Operating phase: RUNNING_PHASE Operating mode: REDUNDANT Total supply power: 2800 W Route processors: 120 W Linecards: 402 W Chassis components: 887 W Total inuse power: 1409 W Remaining: 1391 W
Table 3 show power-mgr Field Descriptions
Field Description
Powershelf type
The power subsystem in which the power supply modules ( PEMs ) are installed.
Operating phase
Operating mode
Redundant or Additive. The current power calculation mode.
Total supply power
Maximum power available for the zone.
Route processors
Power consumed by two route processors. Dual route processors are calculated regardless of operating mode.
Linecards
Total possible power that consumed by all linecards in the zone.
Chassis components
Total maximum power consumed by chassis components other than line cards ( for example, clock scheduling cards and switching fabric ).
Total inuse power
Sum of values for route processors, line cards, and chassis components.
Remaining
Difference between Total supply power and Total inuse power.
Found on Cisco's Power Management for the Cisco 12000 Series Router:
Hope this helps.
Brad Reese BradReese.Com - Cisco Power Supply Headquarters
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Jobs
I tried show gsr power-mgr but it does not work. The "power-mgr" option is not there.
It is a 12410, the command I got for power information is show environment voltages but the information displayed is not easy to understand.
Any idea ?
Any idea ?
