CCNa w/ 5505
Feb 03, 2008 2 Replies
I'm getting a 5505 for home use and wondering ... I would like to get a CCNA, would I be able to do this with this firewall?
No. Firewalls are not covered in CCNA, CCNP etc.. There are specific security exams and qualifications but for CCNA you would need to be looking at something like a couple of 2600 series routers and maybe a low end switch.
Chris.
I'm taking the two cources as we speak, and bought a Que Publishing self study guide up front for preparations, which states this for self study:
. at least on 2514 or higher router . one additional oruter, like the 2501, with one ethernet and two serial ports, to test wan's. . at least one switch, ideally a 2900XL or 2950. A 1900 with Enterprise IOS (needed for having a CLI) will do . a DB-60 DTE to DB-60 DCE cross-over serial cable . at least one roll-over console cable . multiple straight and x-over ethernet cables
It's mentioned that Catalyst 1912's and 1924's can be used, though they differ from current production models WRT syntax..
