Cayalyst 5500 Problem
May 27, 2007 1 Replies
I have a Catalyst 5500 with a SUP2 and a Route Swtich Module. I am using the NAT on the RSM to translate between our 192.168.1.0/24 network and our ISP IP address which is a Comcast cable modem. I have everything working, except that I cannot VPN into my workplace. It seems to be a NAT issue, but I have tried many different methods and I cannot get a connection through. Any help would be appreciated.
What are the tests you performed to prove that your NAT is the problem? Do you have a web server connected to the Cat5500? Can you access the web server from the Internet? Is your VPN device configured properly?
