CCM Upgrade to 4.1 on HP DL320-G3
Mar 31, 2006 2 Replies
CCM Upgrade to 4.1 on HP DL320-G3 open original image
Hi all,
I have CCM 3.3 running on a HP DL320-G2 and want to upgrade to CCM 4.1 and HP DL320-G3. Unfortunately, CM4.1-U-K9-7825= does not include the necessary Cisco OS 2000.4.1 CD set needed for the DL320-G3. Only the documentation of
2000.4.1 is enclosed, but no CD (?!).
What is the recommended way to do the upgrade with CM4.1-U-K9-7825=?
Thanks, Dietmar
Do you have the CCO account? Cisco had a downloadable OS upgrade to the version 2000.4(2). Then you may upgrade your CallManager OS to the latest SR
2000.2(4)SR5a. Just go to the Cisco website
), search for "2000-4-2", download the Major upgrade (win-OS-Upgrade-K9.2000-4-2.exe).
Good luck,
Mike
