Catalyst 3550 and IAS authorization
Mar 31, 2006 21 Replies
Is VLAN 6 a mgmt VLAN for swithes ?
Assuming you are using trunking between 3350 and layer 3 switch
10.10.6.253 ?
So IAS authnetication problem only ocurs when you telnet to the mgmt IP address assigned to the 3350 (10.1.6.250) - is that right?
Does the authentication problem occur everytime when you telnet to this switch?
I found and resolve my problem. On L3 switch which is my router to VLANs communicate with I set UDP helper for RADIUS packets. And this makes so kind of troubles. So, when you have to configure UDP helper (or ip helper-address in Cisco nomenclature) you shouldn't set ports other than BOOTP/DHCP 67 regarding to
. Regards Slawek
