Cat 4500 police rate issue
Aug 31, 2007 3 Replies
Jump to replies (3)
I have a strange problem with a service-policy in a 4503. I set up the policy to rate limit all traffic with DSCP AF21 to 8 Mbps. However when I apply the configuration instead of give me 8 Mbps it rates limit the matching traffic to 200kbps or something very low around this number. To get around 2 Mbps I needed to change the configuration of the policy to conform 60Mbps! The policy match perfectly the traffic (other traffic not matching is not affected and I can see the matches in the policy). I guess I am missing something but I cannot find it. I am doing exactly what the documentation says (well I guess so). Any ideas?
Thanks!
The config and some output: sh run Building configuration...
Current configuration : 3367 bytes ! version 12.2 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption service compress-config ! hostname Switch ! boot-start-marker boot-end-marker ! ! no aaa new-model qos ip subnet-zero ! ! ! ! power redundancy-mode redundant no file verify auto spanning-tree mode pvst spanning-tree extend system-id ! vlan internal allocation policy ascending ! class-map match-any p18 match ip dscp af21 class-map match-any p0 match ip dscp default ! ! policy-map pol1 class ph2k18 police 10 mbps 8000 byte conform-action transmit exceed-action drop ! ! Extra config removed ! ! interface FastEthernet3/33 switchport trunk encapsulation dot1q switchport trunk allowed vlan 3 switchport mode trunk qos trust dscp service-policy input pol1 ! interface FastEthernet3/34 switchport trunk encapsulation dot1q switchport trunk allowed vlan 2 switchport mode trunk qos trust dscp ! interface Vlan1 no ip address ! interface Vlan2 ip address 172.16.1.1 255.255.255.0 ! interface Vlan3 ip address 172.16.2.1 255.255.255.0 !
Switch#sh qos int fas 3/32 QoS is enabled globally Port QoS is enabled Administrative Port Trust State: 'dscp' Operational Port Trust State: 'dscp' Trust device: none Default DSCP: 0 Default CoS: 0 Appliance trust: none Tx-Queue Bandwidth ShapeRate Priority QueueSize (bps) (bps) (packets) 1 N/A disabled N/A 240 2 N/A disabled N/A 240 3 N/A disabled normal 240 4 N/A disabled N/A 240
Switch#sh policy-map interface fas 3/33 FastEthernet3/33
Service-policy input: pol1
Class-map: p18 (match-any) 890162 packets Match: ip dscp af21 (18) 890162 packets police: Per-interface Conform: 1019987148 bytes Exceed: 297053015 bytes
Class-map: class-default (match-any) 525 packets Match: any 525 packets
How are you generating the test traffic? How are you measuring the rate?
The burst size you have configured is very small. try to adjust this to 128000 for 10mbps
John,
I did and it worked. Thanks!
-as
