C2950 SI and CoS
Mar 31, 2005 4 Replies
Jump to replies (4)
Colleagues,
Do you know if Catalist 2950 running _Standard_ Image is capable of properly processing 802.1p CoS marked frames ?
If I mark a vlan with "set cos" on a router, will the catalist prioritize this traffic accordingly?
Thanks a lot for any input.
Yes, provided CoS is configured properly on the switch.
How can I make sure that this is actually happening? show what ? debug what? If you know this from experience, how did you make sure?
The Standard Image has no CoS configuration statements. That is what my question was about: if 802.1p will still work on a Standard Image if the Ethernet frames are marked properly according to the 802.1p specifications.
Or better yet, if we have a switch running Standard Image between two switches running an Enhanced Image, will the 802.1p CoS information lost in it or what?
I am afraid you did not understand my question.
